1st Gen GP GP Intercooler wanted
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by UKXPAT, Nov 27, 2009.
  1. BlimeyCabrio
    Scangauge will give you more accurate boost/map readings than your mechanical gauge... if'n you really want to know how much you're making. but it's not as much fun as watching the needle move around. :lol:
  2. UKXPAT
    UKXPAT New Member
    Nov 12, 2009
    143
    Crystal Lake, IL
    I got Jan's (RMW) old Scangauge II. Not sure if he ever set it up completely, but what do I need to do to get accurate MAP readings. I hear about the 'subtract 14.5', but at low rpm I would have a negative number if I did this. What kind of readings should I expect to see? This may mean Jan set it up for CA. I still need to set up for DFW area in TX, so an advice would be welcome.
    You should see negative numbers unless on boost. Remember the engine pulls a vacuum when not boosted.
  4. BlimeyCabrio
  5. UKXPAT
    UKXPAT New Member
    Nov 12, 2009
    143
    Crystal Lake, IL
    I see positive. About 8.0 at idle.
  6. BlimeyCabrio
    That's MAP, not boost.
    8 psi MAP is about -6 psi boost (vacuum).
  7. Newbs49
    Newbs49 New Member
    May 23, 2009
    145
    Your about right. Idle should be about -10
  8. UKXPAT
    UKXPAT New Member
    Nov 12, 2009
    143
    Crystal Lake, IL
  9. ScottinBend
    So I think I got mine working right......when would I see the boost go positive on the Scangauge....only WOT?
    I am also seeing a reading of -6.o at idle. I am at about 3500 ft elev.
