GPS Question
Discussion in 'MINI' started by TGS91, Sep 3, 2010.
  1. RonsMinnie
    RonsMinnie New Member
    449
    Sugar Land, TX
    #21 RonsMinnie, Sep 3, 2010
    I think this is a matter of semantics ---- you can down load your route/waypoints to your device. -- to use Mapsource:
    First connect your Garmin device to you computer and then navigate to the "mygarmin" site--
    https://my.garmin.com/mygarmin/customers/myGarminHome.faces
    Log in or register
    Then choose manage maps and follow steps to download -- after completing the preliminary steps of sn# & product code -- You previously purchased maps (probably just the map that was own your Nuvi when you purchased it) will appear in a dialog box and you then proceed to download these maps to your computer
    Look for the box that says "download options" when this is chosen you have a option to download the map to your computer.
    Once this is downloaded when you open MapSource your downloaded map will appear and you can choose routes and way points and create your route.
    You then can download the route/way points to you Nuvi.
    So technically you are just downloading the way point to the NUVI not the map. You can also upload your "tracks" from the Nuvi and map where you have been.
    Sorry if this is not clear -- I am just learning these processes. But bottom line is - you can plan routes and get them to the Nuvi.
  2. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Thanks Ron, I know the area you are talking about on the mygarmin site. I'll fiddle around with it.
  3. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Think I got to the bottom of the issue
    The 1260 I have does not have the 'plan ahead/advanced navigation' feature that MiniDave has on his 1400 series
    I am assuming Ron has something similar as I cannot find the menu choices you mention at My Garmin.
    Hmmmmm Garmin upgrade?
  4. YeloMini
    YeloMini Member
    Jul 7, 2009
    234
    #24 YeloMini, Sep 6, 2010
    Pretty much all the Garmins with a number other than Zero in the Routes line of the Specs tab on each device's page support loading of custom routes. The new 3700 series doesn't though. They dropped Mapsource supported routes in that line for some unknown reason. Many of their other models do this. I use a Nuvi 550 for twisty backroad navigation in my Mini and on my sportbike. Custom routes are no problem for it.
    When you find a Nuvi that supports imported routes, the one thing you have to check is if it is calculating it the same way as you had it in Mapsource. The Zumo line is rumored (I haven't confirmed yet) to be able to take a pre-planned route and give guidance on that route without first recalculating it. None of the current Nuvi's do this. You can send ones that support routes a route, but before it will gives you directions, it recalculates it based on it's own route preferences. That can mean a lot of time in Mapsource using more waypoints and via points to make sure the device gives you the route you want. Older device like the Streetpilot 2610 were able to take a Mapsource generated route and guide you on it without first calculating it.
    So check the specs tab on Garmin's devices to be sure there is something other than Zero in the Route field.
  5. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Apparently they've made it more confusing as MiniDave's 140X appears to do this function... :crazy:
    Thanks!
  6. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Did some digging and you need to set the overall preferences or 'avoidances' when you program in a route. If you have a stored route full of twisties and you set your preferences before you hit 'go' on that route to avoid toll roads, highways and the like you should be good
    Also the more granular you make your routes probably best. These are mini computers and are going to do basically what you tell it to do. I'm thinking using the 'intersection' setting option in routing maybe best. We shall see
    That said I'm gonna upgrade to the 1490T (does the routing and accepts the Eco Route HD). Amazon has em' for $219
    Gonna put up my 1260 here and NAM and recoup some of the cost
  7. lotsie
    stagehand/part time detailer
    Right here
    The 1490T, is what we have. Works great with the Eco HD. Have not tried
    putting in pre-planned routes yet.
    Mark
  8. Metalman
    I have a Garmin nuvi 265W.
    I have unsuccessfully been trying to download a google map route to my Garmin. When I go to export the map (with the 265W connected to the computer), it only gives me an E-mail option, it doesn't recognize that the 265W is connected.
    Any suggestions as to what I'm doing wrong? Followed your points Ron, still not doing something right.:mad2:
  9. YeloMini
    YeloMini Member
    Jul 7, 2009
    234
    Unfortunately, the 265w doesn't support custom routes. I would bet that's why it's not an option.
    If you look at the specs tab on Garmin's site, you'll see a zero there. If it's like the Nuvi 660 I have, you can add 1 via point in between your current position and destination, but not more than 1. Which makes creating your own route for motoring difficult. Since the 265w supports custom POIs, you could create POIs at various locations to force it to route that way, but as you drive you'd have to select each one as you reach them. Which is kind of a hassle. Better option would be to upgrade to one that supports custom routes.
  10. Metalman
    Thanks YeloMini.....
    Now I can stop scratching my head and let the hair grow back.:D
    Yep, time for an up-grade.
  11. YeloMini
    YeloMini Member
    Jul 7, 2009
    234
    When shopping for an upgrade, if it's a Garmin, you want one that has something other than zero in the "Routes" option on the Specs tab. Or pick one that supports "Multiple Point Routing." Garmin's site let you pick a feature and see which models support it. Click on the left side for Multiple Point Routing.
    https://buy.garmin.com/shop/shop.do?cID=134
  12. Metalman
    Thanks,
    I'm leaning towards the 2360LMT. Lifetime map upgrades and traffic (I think that gets rid of the annoying coupons). It can hold up to 100 routes (I assume that's the ability to do the custom "Google Maps"). Looks like it is available in the 4th quarter, but can't find a source yet.
  13. Justa Jim
    I'm looking at the Garmin 2360lt. It says it will be released in the 4th quarter which is now.
  14. Metalman
    Yeah Jim, I was looking at the 2360LT too, but I figured with all the highway stimulus money I'm spending:cryin:, and new roads going in all the time, another $40.00 for the 2360LMT, at least I'l be able to find all the roads I bought.:mad5::cryin::crazy:
  15. Minidave
    If it has traffic, it will have coupons.....
    You can turn off the traffic, and the coupons go with it (unless you've added the HD module, then for some reason you can't) but if you want traffic, you'll have to put up with coupons - sucks completely in my book.
  16. Justa Jim
    How often do the coupons show up and how do you clear them?
  17. Minidave
    There seems to be no rhyme or reason as to where or when they show up, but in town it seems like there's always one on.
    You can change the screen momentarily and it will be gone when you go back to the original screen, but it will pop another one up almost immediately - again depending on where you are.
    Like I said, pisses me off royally......but that's just me. They don't take up the whole screen or anything, but I just think the whole idea of them is wrong
  18. Metalman
    Yeah.....
    You've been driving for like 8 hour straight. Trying to make it home without spending for a motel. You've skipped too many nature breaks. You just pass a "Big Boy" thinking about their "Super Big Boy" and then up pops "Free Fries". Man..... How can you turn that down. I mean Super Big Boy with free fries.....
    There goes the big plan..... You'll never make it home tonight....... Free Fries, man, free fries......
    Damn coupons...... I hate them.....:D
  19. Justa Jim
    Gee thanks Chuck. Now I have this need to go get some French Fries. :nonod:
  20. Justa Jim
    Just checked Garmin and Amazon. They do not offer the 2360 just by itself. I guess ya get the coupons, like it or not. I have the traffic on my current one, but never looked to see if I could turn it off. If you have the device always connected to the power source (via the FM traffic pick up) I wonder if it could be turned off to stop the coupons. Have you tried Dave?
