Greene Performance Caster/Camber Plates
Discussion in 'Suspension' started by ColinGreene, Jun 27, 2015.
  1. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    Bump - come on people let's make this happen.
  2. Zillon
    Zillon Well-Known Member
    Jul 12, 2014
    702
    632
    Central NJ
    Interested to see this go through - and eventually see some R56 versions.
  3. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    Right i am as well but without completing the group buy to get this moving its not going to happen. Thats the problem we are facing right now.
  4. Firebro17
    I'm feeling the pain Colin. Have you got a time frame for tossing in the towel on the group buy?
  5. cct1
    I'm scratching my head. Why isn't this done already? We've been begging for years for plates that can adjust castor, here they are, and there aren't enough people? If you're riding the fence and this fall apart, you're going to be kicking yourself if you understand what you just lost out on....
  6. Firebro17
  7. Shifter
    Shifter Member
    86
    24
    Southeast Michigan
    Thank you cct1 !
    Understand that we Gen 1 owners are definitely a niche target audience. There are not many companies willing to do what Greene Performance is offering to do for us. Therefore we need to support those that are willing to work with us and for us.
    If this group buy falls apart, you can forget about anyone else making these camber/caster plates for us.
    Yes, as you may have guessed, I am order number 1125.
  8. Firebro17
    So, now the three of us are out in the open. Your comments hit the nail head dead nuts.
  9. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    What is a typical "use case" for these plates?
    As in: when do you need these and what do they give me the stock BC coils don't get me. I just had my car aligned and it is exactly what I asked them to do (although to get there they had to max out the BC plates to max negative).
    In front I am at zero toe, stock caster, and - 1.75 degrees camber, down from a rather useless -2.5 degrees on my old setup (tire wear, bad braking, tire slip under accel). Happy with what I have. What would make me happier I can't have unless I join the group buy?
  10. Dave.0
    If anyone is wondering why would you want to be able to change the caster?
    Adding caster will make the steering feel more steady on center, and it also decreases the need for extreme camber angle for front end grip. with additional caster as you turn the wheel off center it adds camber meaning the front end will not need more than two degrees of camber anymore.
  11. cct1
    Like Dave said, and I wrote earlier in the thread: if you are able to take out the negative camber to -2.0 by adding castor, you get the same excellent grip of -2.5 camber without the castor in turns, but with the less camber and added castor, you get improved acceleration and braking when the wheel is straight, it's a win-win. Tire wear will probably be better too.
  12. Savvy
    It's for legit handling performance versus the dapper/stance look. If i wasn't in the process of buying a house right now... I'd be #4 on the list.
  13. Firebro17
    It's an expense to be sure, but plenty worth it. Great bit of info Gents!
  14. Metalman
    Colin....
    Three major plates seem to be involved here...
    The R53 specific damper mounting plate...
    The castor plate...
    The camber plate...
    So if you came out with a R56 specific damper mounting plate... and also a F56 specific damper mounting plate, you would increase the "group buy" interest with seemingly a small change.... Maybe?
    It may be harder to spark interest by being limited to just the R53 on the current offer...
    Of course you may have already considered this....
  15. ColinGreene
    438
    293
    Orange county Ca
    Like i said, I have R56 parts under development so it wont take long to have the drawing finalized.
    I already have the part in hand and have started.
    I have not considered the F56 as much since people dont seem to express a lot of interest in modifying the car.
  16. Metalman
    Yeah, I read this earlier in the post...
    Was just suggesting you include the other gen's as a possible way to get the interest up for the group buy with minimal risk...
  17. fishmonger
    May 13, 2015
    984
    769
    Madison, WI
    thing is - it will only add noticeable performance if you drive the car in a way that you can dig into that added camber while turning, which in my world simply doesn't happen often enough to justify the expense right now. My car needs a lot of other things that are of more immediate benefit (exhaust, seats, CV boot replacement, etc.)
    I appreciate that Colin does these things, but I am new to the Mini world with many still open to-do items for the car, while my budget is limited these days with my son wanting his own R53, which doubtlessly will become the same money pit the first R53 has been for me :)
    I'm not complaining - I've never had more fun wrenching in my garage, but my funds are limited and I have a long list of mods and maintenance items that are still to be addressed. Looks like the camber/caster plates would be a nice addition, but right now I need to prioritize where I spend my play money. Until my Tundra is sold, all further Mini mods are on hold. If the deal is still open in a month or two, I may still sign on.
  18. sethat46
    sethat46 Well-Known Member
    Apr 25, 2012
    1,560
    413
    Financial Sales
    Ohio
    Well. I do want these plates but I still must buy swift springs and figure out other issues right now.
  19. Metalman
    Swift springs are soooo nice...
  20. Savvy
    Best bet is to handle all the regular maintenance needs before starting on your path to "full retard" mode.
