Greene Performance Caster/Camber Plates
Discussion in 'Suspension' started by ColinGreene, Jun 27, 2015.
  1. clifforddward
    clifforddward Active Member
    Dec 2, 2013
    104
    76
    Cary, North Carolina
    #81 clifforddward, Jul 24, 2015
    For those wondering about the advantages of these Green Performance caster/camber plates, I thought some might be interested in comments I received from Colin during a recent email exchange we had when I asked about the function of these plates...below are some excerpts. Once one understands exactly what these plates do and the advantages they offer to car set up, the buying decision becomes a no-brainer. The potential for reduced tire wear alone makes them quite useful...
    Comments from Colin:
    "...with additional caster put into the front end you have much less need for static camber that wears tyres. Also adding front caster will help the front end feel more stable on the highway as well as add a bit of steering weight to the front end. The entire reason i started building these was I drove a mini with added caster and had to have them...."
    "...It is a bit of a take on the JRZ design for the plate but we significantly changed a bunch of factors on them to make them actually function well for a mini. Some of the design work JRZ had was a bit incomplete...."
    "...As far as making sure the front end is dead accurate, with these plates they will be "infinitely" adjustable, meaning no pre set slots...So in a nut shell whats good about that?...Inherently since metal moves around with heat when the car is stamped and welded together it makes the car slightly twisted from one side to the other, with these plates and a bit of time you can make it completely perfect..."
    "...The other thing thats nice is that with less need for such aggressive camber angles you don't have to really worry about tyre wear as much..."
  2. CHKMINI
    Even though these don't fit my Coupe, I want to see this move forward so that the Gen 2 design will make sense for Colin to design. When/If that happens I'm all over them. C'mon R53 guys....order up!!!!!
  3. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    Ill have stuff that fits your coupe if you want on the group buy.
    Its not a problem.
    Ill work something out with the machinist to get the parts done.
    only the top plate will need to be changed for the part to work.
  4. TheModFather
  5. ColinGreene
    438
    293
    Orange county Ca
    is it not the same bolt pattern on the top?
    I have limited experience with them.
    I have only driven one once, it was dales, greg zito was in the back and i thought he was going to have a coronary if i drove it over 25 miles an hour.
  6. TheModFather
    Not sure...
    Probably the same... Use that parts bin for all its worth BMW.
  7. CHKMINI
    Put me down for a set for my Coupe.
  8. Metalman
    Do a reverse lookup on Real OEM...
    See here... All of these use the same OEM Top Strut Bearing....:Thumbsup:
    RealOEM.com - Part Search
    The flood gates have now been opened...:D
  9. ColinGreene
    438
    293
    Orange county Ca
  10. CHKMINI
  11. Firebro17
    What's the count Colin?
  12. ColinGreene
    438
    293
    Orange county Ca
    Should be 8 now. Two more.
  13. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    Come on - if you don't have camber plates already and you consider yourself an 'enthusiast' or 'hardcore' -GET A SET!!!
  14. ColinGreene
    438
    293
    Orange county Ca
    we are two people short of making this happen!
  15. Shifter
    Shifter Member
    86
    24
    Southeast Michigan
    If more speed is what you want, the smart thing is to keep what you already have by not giving it up in the corners. These plates will help you do that.
  16. Firebro17
    Judas Priest man! Where are all the non-bench racers?! Heck, and it's only just a few bucks ta boot.
  17. BlimeyCabrio
    If I had these plates already, my car probably wouldn't look like this.
    Be smart! Don't be a statistic! Expand your limits! Ante in for these plates!!!
  18. sethat46
    sethat46 Well-Known Member
    Apr 25, 2012
    1,560
    413
    Financial Sales
    Ohio
    I'd be in if I didn't have other projects/things to fix already and wasn't a poor ex-college student struggling through life. Ha!
  19. ColinGreene
    438
    293
    Orange county Ca
    True you do drive a hot mess.
  20. sethat46
    Apr 25, 2012
    1,560
    413
    Financial Sales
    Ohio
    Yes. But she's my hot mess! I mean.... Project.
