Greene Performance Caster/Camber Plates
Discussion in 'Suspension' started by ColinGreene, Jun 27, 2015.
  1. BlimeyCabrio
    Dude, those look FANTASTIC
  2. cct1
    That they do. Glad this got done!
  3. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    970
    732
    training specialist
    Maysville, North Carolina USA
    I am so looking forward to putting these on! :drool Colin, email sent.
  4. TheModFather
    You can't see them once they are on the car... I do like that Green though!
  5. BlimeyCabrio
    You can see a little of them...
  6. BlimeyCabrio
    So, looks like you set approximate desired caster (amount to add to stock) with the outboard slider & bolts before installation. Hopefully there's enough clearance to reach the inner bolts with a ball-end wrench to adjust camber on the car, without cutting the towers. Though I've cut my towers before, no big deal.
  7. Zillon
    Zillon Well-Known Member
    Jul 12, 2014
    702
    632
    Central NJ
    Well, considering I'm buying a R53...
    I might have to add these to my parts list.
  8. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    I sent out the first five on black friday. I came up short on some other hardware so ill be waiting for that to get the other 5 out. Its only a day or so out.
    Zillon let me know if you need a set. I cut parts to make 30 pairs.
  9. CHKMINI
    Looking forward to getting mine.
  10. Firebro17
    Got mine today Colin. Outstanding! Contemplating parting with the R53, but I've slept since then....
  11. Zillon
    Jul 12, 2014
    702
    632
    Central NJ
    Currently trying to figure out which coilovers I want - pardon my ignorance, but I've missed a lot of discussion in the thread.
    I'm assuming these work with anything designed to use the stock upper strut mount, right?
  12. ColinGreene
    438
    293
    Orange county Ca
    Yeah i saw that and was wondering what that stress test really did to you.
    I knew it must have done something because you forgot to call back.
  13. Firebro17
    I didn't forget... I've got you on to do list. Thanks for the reminder!
  14. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    Arrived yesterday! SWEET! Way to go Colin!!!!
  15. BlimeyCabrio
    So Colin.... Want to share with us some pointers for setup?
    As in... if we adjust caster all the way forward vs. all the way back, approximately how does that compare to stock?
    Ditto for the camber adjustment?
    I'm trying to figure out a preliminary starting point before I take it to be aligned. And looks like caster needs to be dialed in before assembly, anyway.
  16. cct1
    The answer for caster: all of it.
    Camber:-2.0.
    That's the starting point. According to Jan, you can back off camber a bit with the added caster. Less camber=better straight line acceleration and braking, the caster allows you to run less camber but keep the grip in the turns.
    Jan does some stuff with toe too, but I'm starting at 0 toe up front most likely, and a little in the rear.
  17. Nathan
    Ewww....
  18. BlimeyCabrio
    Yeah, I get all that. I'm asking Colin specifically how these plates work, what we should expect at the limits, etc.
    I'm also aiming for max caster, -2 camber. I like a little toe out in the front (like 1/8" total), and a little toe in, in the rear (like, 1/16" total). Or something like that.
  19. cct1
    Pretty much what I'm doing, minus the camel toe out in front.
    (That was just for you Nate).
  20. MCS02
    I have camber at -2.0. but my toe is opposite of you with a little up front for turn in and 0 on the rear.
