1st Gen R53 Cooper S Guess what this was...
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Nathan, Apr 8, 2010.
  1. ScottinBend
    I thought someone was working on an OEM replacement that was of a better design.
    :confused5:
  2. jhiggs26
    jhiggs26 New Member
    May 24, 2009
    159
    10
    Nathan what's your style of driving and car usage? Is it a city driver? Are you a clutch in at the light guy are are you a neutral lover? Double clutching everywhere?
    What are you putting back in? New guide tube and throw out bearing and OEM clutch kit etc? Hope you're mobile again real soon!
    Jeremy
  3. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #23 Nitrominis, Apr 13, 2010
    It is how you read through the advertising? But when you look at the T/O bearing nothing has changed? Not sure what you would do anyway? Maybe a Kevlar or composite plastic non lubricating T/o for the track IDK? Most all suppliers buy from a couple of companies and than package them with their plates and discs.
    beaner...Unless OsGiken has changed using standard industry roller bearing assembly it is much the same components used for years. The actual t/o bearing itself is manufactured in Japan and OsGiken assembles it to their sleeve assembly.
    Top Page | OS GIKEN
    I don't drive often since I work from home and when I do go out it 50/50 around town and longer distances that are mostly highway.
    At a light I put the car in neutral. The transmission has sycros so there is no need to double clutch. On downshifts I do match revs.
    Since we were in there the entire assembly has been replaced, clutch, pressure plate, bearing and flywheel.
  5. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    And so what did we put back in there given your 50/50 driving and the hope of future track days?
  6. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    Yes, OS Giken has a unique clutch release bearing; all metal construction and precision dual rotating assembly. The OS clutch release sleeve assembly is only compatible with their clutch kits as Greg stated.
  7. drksilvermini
    drksilvermini New Member
    May 23, 2009
    24
    Student at Northwood University
    Harrisburg, PA
    My friend is a tech and recently replaced the clutch on an R53 and the clutch looked exactly like this. 3 pieces almost exact same size. Weird.....
  8. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Looking closely at the surface area I can see what was going on. This is not caused by a defect of any kind :lol:
    I would like to see a picture of the other side which would tell the complete story.
  9. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    #29 Way Motor Works, Apr 17, 2010
    I haven't seen one on an S come apart that bad before.
