Greetings! I have two pairs of H&R Trak+, DRA type, MINI-spec wheel spacers for sale. I bought them new from Turner and they're still unused and in their original boxes. I mounted one set, once, and then removed them (without even lowering the tires to the ground) and put them back in the box. That's it, just one test fit and they've been sitting in their boxes ever since. These are 25mm each (they're called a 50mm set because the set widens the overall track 50mm) and they come with bolts. This is the type that bolts to your hub and then you bolt your wheels to the spacer. Check them out elsewhere if you like (model # 05024562) and see the pics below. The cheapest I can find them online today is something over $140 per set (plus shipping). I'll sell at $65 per set plus actual shipping from 20646 -- that's La Plata, MD, in case you're local and want to save the shipping. thanks for looking!
