1st Gen R53 Cooper S Hard starting when below 1/4 tank of fuel
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by jasonsmf, Mar 4, 2016.
  1. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    It is totally normal overnight for the fuel pressure to drop enough that you have to prime the system again. I always do it, every time I start, just because. If it needs to be primed after just a few minutes at a gas station, then there's an unusual leak somewhere, most likely back into the tank (you'd smell gas if it was anywhere else). I am guessing the fuel pump itself has some sort of check valve to the line it feeds that may at some point in time begin to fail.
    The tank itself can be fully sealed with perfect gaskets to the outside world and the pressure will still leak out of the fuel line back into the tank, as there is always air in there that will compress, plus the gas cap will never seal perfectly.
    Prime and drive - I had my car parked for 5 months before starting it Saturday - two prime cycles for good measure, started right up, just a few cough moments after that and purred right out of the driveway.
  2. jasonsmf
    jasonsmf Active Member
    111
    27
    engineer
    Elyria, Ohio
    I understand what you are saying; but I'm trying to determine the source in this change in behavior of my car. In the first 190,000 miles or so, never once did it require waiting for the system to prime. Only in the past year have I noticed this condition, and ONLY when the tank is low.
  3. fishmonger
    May 13, 2015
    984
    769
    Madison, WI
  4. jasonsmf
    111
    27
    engineer
    Elyria, Ohio
    Brand new VDO fuel pump installed over the weekend. Problem solved, case closed!
  5. 00Mini
    Thanks for posting the fix.
  6. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    The good thing is, your fuel pump didn't totally fail and leave you stranded like mine did a few years ago on a club drive.
    Motor On !
