1st Gen R53 Cooper S Headwork - general discussion 2.0
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by BlimeyCabrio, Mar 15, 2010.
  1. racingheads
    racingheads New Member
    Mar 10, 2010
    10
    Honda master technician
    Kenosha, Wi.
    We got some good discussions going on here in the threads.
    No matter how good the cylinder head works, the restriction on the intake side, starts with the intake manifold.
    A intake manifold is a continuation of the cylinder head. This is where a flowbench comes in.
    With the intake manifold bolted to the cylinder head, with the throttle body installed, reflow the intake port, then compare the data.
    1) if the intake port flows 220 cfm
    2) with the intake manifold flows 200 cfm,
    the loss of estimated power is 20 cfm, or 22 hp.
    Now, knowing where your intake restriction lies, you would want to do modifications to the manifold to decrease the loss, or get each port runner close to the desired cfm.
    Once that is done, the next step, would be with the intercooler attached.
  2. racingheads
    Mar 10, 2010
    10
    Kenosha, Wi.
    Oops, I was thinking outside the box. This would be for non supercharged.
    Still, doing a flow test with the intake manifold is the next step.
    The intercooler can also be flow tested by it's self. These are critical area's of concern.
  3. CarlB
    CarlB Active Member
    54
    Thank you for all the work getting this back BlimeyCabrio. I appreciate your and Nathan’s efforts.
    Matt, Thumper, and Jeff make some excellent points. What is important is the combination. Engines have been called air pumps, and it is true. To make power you need combustion. That takes air (specifically oxygen) and fuel. The limiting factor is pumping air. You can make the tailpipe black with too much fuel. Packing the cylinder with the most air involves every part from the air filter to the tip of the exhaust. The engine speed, the engine will pack the greatest amount of air is the point the engine makes peak torque. Air, and specifically in the case of a running engine, air and fuel mixed together have mass. The air fuel mixture does not stop and start instantaneously. The valves do not open to full lift instantly. Camshafts have both valves open at the same time to overcome the fact it takes time to get the air moving through the port. All the pipes (intake manifolds, cylinder head ports, exhaust headers) have internal dimensions. When the piston falls on the intake stroke it displaces a certain amount of volume. Depending on the speed of the engine you get volume over time. I will leave the blower out, but it is just like a piston except it pushes. The point is the gas will move through the pipes at a specific speed given a specific engine speed. The camshaft uses the opening and closing points of the valves to optimize starting and stopping the movement of air in the pipes to affect the filling of the cylinder. It uses the rate of change in valve lift to help this process. Remember that the piston stops at the top and bottom of each cycle, therefore the piston is moving at different speeds as it descends the cylinder. The affect is the amount of vacuum created is constantly changing. This can get real complicated real fast. The head, intake, and exhaust need to have their internal dimensions shaped so the air can move without restriction. Bigger pipes are not better in every case. It turns out that engines will pack the most air when the velocity or speed through the pipes is at a specific speed. Make the pipe bigger and the speed that the engine will make peak torque will increase. Remember the mass thing from above. The air will keep flowing even though the piston has started to go back up the cylinder. The best flowing pipe would not have any turns and would not have a valve in the way. Car engines are designed to allow the hoods (bonnets) to close, and all engines require valves. The point is the pipes have a lot of restrictions. Production parts have manufacturing limitations for cost. The ideal port or pipe would be the smallest cross section without creating turbulence and that created the ideal gas speed at whatever speed you wanted the torque peak. A larger than ideal port with turbulence might create peak torque at the same engine speed as the smaller port, but the performance below peak torque would not be as good.
    Matt is correct there are plenty of books on this, and I am starting to write one, so I will stop.
  4. racingheads
    Mar 10, 2010
    10
    Kenosha, Wi.
    Are all stainless valves the same or which ones are better?
    For the Mini Cooper they offer standard, .50 mm, 1.0mm, 1.25mm, and 1.50mm oversize valves. Is larger better than standard? depends
    Then there is hollow stems, undercut stems, sodium filled, nitried coatings?
    Each manufacture determines the under head radius, or tulip, some are flatter, some a short radius, which are better?
    Valve angles, is the rule of thumb the best? 30 / 45/ 60?
  5. Thumper460
    Thumper460 Active Member
    May 26, 2009
    559
    94
    United States Navy ..Retired
    I'll be the bad guy...
    To the average enthusiast.. the average get on the track once in a while..
    This post is interesting.. It has discussed the HOW ( to a degree) and the WHY ( to a degree). And to the average guy, can start to get into over load!
    How about the NEED??
    Does my MINI NEED the sodium Valves?? or Hollow stem ?
    Does my MINI need the Oversize Valve, to what size?? +.5mm +.15mm ??
    Does my MINI need 96-112-114 cc intake runners..
    All this thread is cool to show the knowledge is out there.......... the Parts are out there............... The Heads are out there!! But what is the use , IF we dont discuss the purpose of what is out there??
    There will still be the guy that will buy a $2200.00-$3000.00 HEAD, and be disappointed!! In the performance... he will , however be able to brag all the "whiz-bang" parts he has!! YES?? But once he pulls out on the street or the track... it will be apparent that he "Over Bought".
    I am of the "School" ( Old) that we help to evaluate and then suggest the Head mod to the customer!! IF He decides to go BIGGER or smaller.. then it is HIS choice.. BUT, How does HE KNOW?? Form posts like these, and the Head mfg's suggestions..yes? Testimonies from others!! I try to sell by APPLICATION, not bottom line!
    As Blimey said earlier.... I understand most things are a matter of trade-off decisions - but it also seems that some relatively "mild" reworked heads actually seem better at just about everything - better or equal fuel economy, better or equal low-end torque, no change to idle manners, and significant mid-range to high-end torque gains.
    I feel this is the answer.... IF you are a RACING Car and Driver.. then you are in the small 10% and all the "whiz-bang" Trick procedures are yours!! If you are with the rest of the 90%.. it is nice to know, but what works on OUR cars is closer to reality!! There are times when the High Dollar Head ISNT right for our car..!! Right Blimey??
    Just me......................................
    Thumper
  6. BlimeyCabrio
    RIGHT! :lol:
    I love this thread.
    Good points made by all.
    I know it seems like Thumper speaks in "code" sometimes... but the part about application is truth IMHO.
    Big numbers on the dyno do NOT NECESSARILY mean GREAT DRIVEABILITY day-to-day. It's important to understand your goals for your car - not just "number" goals, but driveability goals. What trade-off's you're willing to make - because there are trade-offs.
    Example: My car has an automatic transmission. I drive almost as hard as anyone... but the tranny limits available revs (max is about 6700) and requires more low-end to mid-range torque to be fun to drive day-to-day. The greatest BVH in the world isn't going to make big numbers on this car, because I can't access high RPMs. So I want it to be fun for daily driving, fun for an occasional light-to-light contest, fun for an occasional track day, and fun for tearing up the twisties. But I don't care what numbers the dyno produces, because I'm not competing on numbers. And it's NEVER going to be a competitive race car or great track day car compared to truly prepped cars.
    So I have different needs/wants than my buddy who wants the best track day car, has a manual, and is willing to sacrifice some daily driveability to maximize track performance.
    Different needs = different head.
    One challenge most of us have is that we will never have the luxury of testing multiple heads built to different specs (different valve sizes, flow numbers, etc.) on the same car under extended test conditions... so whatever head we have "feels" "best"... While there are some hints in the dyno plot as to how the car will drive on the street, the whole story isn't there.... since most of us don't spend our lives at WOT 100% of the time....
  7. lotsie
    stagehand/part time detailer
    Right here
    I do when I'm on my 50 CC scooter:Thumbsup:
    Mark
  8. BlimeyCabrio
    ^ Touche'
    (or douche')
  9. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    :D:cryin::D
  10. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    :yesnod:
    send me your engine when I am finish you would not be able to make this comment. :lol:
  11. lotsie
    Right here
    There is a big bore kit, kicks it up to 65 CC:Thumbsup:
    Mark
  12. racingheads
    Mar 10, 2010
    10
    Kenosha, Wi.
    Good discussion....I would probably say, for most people, this would be the last item to consider, a modified cylinder head. Usually most people start off with alot of easy bolt on's, looking for small amounts of easy horsepower.
    But for those that have a interest in this direction, you can still have a smooth idle with a substantial horsepower increase and a good torque curve.
    We have seen some good power increase's with a stock camshaft, and a modified cylinder head, stock valves, and keeping the same max rpm's. Add the underdriven pulley, hedder with the cat back exhaust and a tune.
    All things considered.
  13. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Ya but see I was factory Honda trained (Elsinore days)in 2 stroke barrel modifications....:ihih:
    ring.. ding... ding... ding
  14. CarlB
    CarlB Active Member
    54
    Porting and a pipe will make a two stroke fly
  15. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    and piston trimming :Thumbsup:
