2nd Gen R56 Cooper S Heat Shield vs Turbo Wrap?
Discussion in '2nd Generation: 2007+ R55 through R61' started by TGS91, Nov 18, 2009.
  1. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
    there's no need to run a modern turbo car before shut down. Turbo timers went out with the '90's. Modern turbocharged cars continue to circulate coolant and oil for a short time after shutdown.
  2. MightyStripes
    MightyStripes New Member
    81
    turbo blankets work really really well we use them on our Turbo 6 Grand National and GMC tyhoon and they drop under hood temps by 75-120* depending on outside temps. It also speeds the spool up of the turbo as it holds the heat in the exaust side and causes the impler to spin faster sooner. Id say that is the best way to keep heat down you do not want to cover the inlet side as that will increase the inlet temp to the engine and cause knock and posiable damage to the engine.
    If you do a search on SummitRacing.com you will find DEI has a few styles of blankets that will work on most turbos. There around $200 but will help performance and drop the temps that would be reaching your hood and scoop :D
    Our mini is supercharged so I have had no issues with the scoop but just thought Id try and help with examples of Turbo cars we have. My buddy also has a Neon and we saw the same improvments on his SRT-4 if that helps as an example more.
  3. BlimeyCabrio
    Google "Turbo Wrap"
    LOTS of knowledge about this topic on a wide variety of cars. We're not breaking new ground here.... this has been worked through on lots of other platforms that have been turbo'd for a lonnnnnng time.
    The turbo wrap isn't some kind of "Way Motor Works Voodoo" dreamed up after too many margaritas... it's a proven approach. ;)
  4. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    i cant say about having it vs not, as ive had my grille completely removed for a very long time now... heat definately pours out better and my scoop does still look brand new.
    Some have painstakingly dremeld out the other holes, but by then you might as well just take it out lol
  5. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Research I've done is that the hood scoop, assuming some ventialtion, works at lower speeds but when you get into highway speeds the airflow goes above the hood scoop making it pretty useless.
    Looks darn good though and as Fernando says "It is better to look good than....." :lol:
  6. Gil-galad
    Gil-galad Club Coordinator
    May 19, 2009
    1,178
    431
    Decorah, IA
    Fully agree, and in fact the open scoop on the R56 probably serves its owner best after the car has been driven and is at rest, since it provides the escape route via convection for the hot air that would otherwise pool under the bonnet.
  7. Deviant
    Deviant Banned
    Student
    Southern IL
    With the MINI I know it continues to circulate coolant, not so sure about oil, but many cars still use engine driven water and oil pumps so they can't continue to circulate. Turbo timers really aren't needed even in those applications, a few miles of gentle driving or a cool-down lap are all that's really needed after hard running and modern synthetic oils don't coke at the temperatures a normally driven car would be at at shutdown. Back when I was into a different type of car the turbo-timer vs. not controversy was the big thing to debate (that and "Crank-walk") Back then I came to the conclusion that a semi-intelligent driver could replace a turbo-timer most of the time and that they were only really useful for getting people to remind you you left your car running.
    Also, in many places a turbo-timer is actually illegal, there's laws against leaving a car running unattended for different reasons. I know St. Louis is one such place.
  8. lotsie
    stagehand/part time detailer
    Right here
    Like I've been saying:crazy:
    So why not just swap the whole bonnet for a Just-a-Cooper one.
    Mark
  9. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Really not trying to belabor the point but "why"? What properties make a turbo wrap better than a shield to route the heat away?
    I get that it's been done for a looong time and I get several of your saying this is the way to go and the shield is not the best. I still have yet to have someone give me a response outside of a personal opinion or citing past research
    Think I'll do the Googling that Paul recomends and let this go
  10. BlimeyCabrio
    Short version - turbos turn heat and pressure into mechanical energy to make boost. They're designed to see the hottest exhaust gases the car can produce, all day long, every day. They're most efficient when 100% of that heat flows through the "hot side" of the turbo and out the exhaust. Any heat that radiates out of the turbo is wasted energy.
    Putting deflectors, shields, etc. near (but not directly in contact with) the turbo allows heat to radiate out of the turbo. Then that heat must go *somewhere*. It's going to go up, and it's going to flow wherever the under-bonnet airflow takes it. I love and respect orangecrush/mark - but i doubt he would have melted his valve cover without the M7 deflector on there - might have melted his hood scoop, but not his valve cover. The deflector deflected heat away from where it would have gone (up) and sent it where it went (valve cover).
    A wrap keeps the heat in the turbo. Turbos are designed to get VERY hot. They like heat. So wraps work. That seems pretty easy to understand to me. I don't understand why it's counterintuitive to others.
  11. Metalman
    Concerning the turbo heat issue. Regarding the reports of distorting / melting hood scoops, hood stripes (white) turning brown. Both of these are plastic / polymer items that are reacting to the heat. Paint is also a plastic / polymer made from acrylics, polyesters, polyurethanes etc. Should we expect to see damage to the painted area on the bonnet directly over the turbo? I read somewhere where MINI removed some of the under bonnet insulation in order to save a few dollars per car.:mad2:
  12. lotsie
    Right here
    I have been saying this for a very long time now. THE TURBO IS MORE THAN CAPABLE TO WITHSTAND VERY HIGH HEAT. It can do this constantly, even if you never shut down the engine.THE THING IS DESIGNED TO DEAL WITH HIGH HEAT. Shut down "MAY" be an issue, but take off your seatbelt, get your iTunes ready for your next motor, and you are safe to shut down.
    The shield does nothing for performance, it does not keep the turbo heat on the hot side, where it improves performance, it just directs it wiggle niggle up, sideways, backwards, but not out the hot side/exhaust A wrap holds the heat in the turbo, and lets it out the hot exhaust side, where you want it to go.
    So, bottom line. A wrap keeps heat from the plastic bits, and there MAY be some slight performance increases. Simple.
    Not sure if the under bonnet insulation would help or hinder this issue. But I don't like the "LOOK" of the bonnet without it.
    Mark
  13. BlimeyCabrio
    But people have learned not to listen to you. Simple.
    :devil:
  14. lotsie
    Right here
    I know, but I just keep on yakking:crazy:
    Some day I may shut-up, but it will likely be on the sewing site first:arf:
    :prrr:
    Mark
  15. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    Having some grill, as opposed to no grill, may prevent low flying birds or wayward rodents from getting sucked in at high speed :D
  16. BlimeyCabrio
    Screw the rodents. They deserve the fiery death they receive.
  17. MightyStripes
    81
    You should listen now because he is right :)
    :idea:
  18. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Guys,
    I for one heard ya. Now it makes sense to me. My holy quest to achieve maximum heat management for my turbo has ended. Mightystripes, Metalman, Lotise, Blimey....Thanks
  19. Dwight
    Dwight Racing with the Gods
    329
    12
    RETIRED!!
    San Marcos, Calif.
    Turbo Wrap=Bearing Failure
    All the comments about turbo heat management are quite correct while the engine is running and the car moving. When it stops, the last thing you want is something that holds the heat in the turbo, like a wrap. The bearings will eventually cook. A shield like m7's will allow convection currents to cool the turbo normally and not melt the scoop at the same time. It is not intended to be a performance mod. BTW, my OEM scoop had the holes in it. It melted anyway. Put the shield on and no problems since (+8K). See the NAM thread's on this, there's only about +200 posts!
  20. Metalman
    Sounds like a choice...... Keep the heat in and you coke your turbo bearing (after the time on the water circulation stops). Let the heat out and you melt your hood scoop / valve cover. :yikes:
    Maybe a period of moderate driving after the aggressive romp to let the exhaust temperatures stabilize? :Thumbsup:
