1st Gen R53 Cooper S Heat Wraps for Headers
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by DMAN, Dec 23, 2010.
  1. DMAN
    DMAN New Member
    Nov 7, 2010
    22
    What length of wrap do you need to cover a R53 header?
  2. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
  3. Mr. Jim
    I have yet to see anything apllied by spray-can that holds up. maybe it would stand a slight chance if the metal was blasted first, but straight over, I don't think so. It does say that it is used OVER the wrap, which might work if the wrap keeps the temp down.
  4. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    Personally i would suggust 30 ft. Just know that it is very hard on the header to keep all that heat in it.
    But the wrap keeps engine bay temps down extremely well.
  5. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    Yes I have heard the same thing about wrapping headers being hard on them, but I wish I had some way to keep the heat out of my cabin, it is the only drawback I have encountered with my Mynes V2 header. Other than that the V2 is one of the best mods I have installed.
  6. minimark
    Header blanket? ;)
  8. Mr. Jim
  9. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Some of us old timers on MINI forums have seen many threads and posts over the years with regards to hedder wrapping. If you are using a stainless steel hedder of fair to good quality it is not likely you will ever have any (hard on hedder) issues.
    Wrapping was a common practiced art in my shop for over 30 years to control exhaust temperature and maintaining exhaust speed velocity and radiant heat control.
    If you are wrapping steel pipe proper preparation by way of sand or bead blasting and than applying heat paint. (*none curable is always the best for exhaust) Wrapping the exhaust component using the wet technique is the easiest and than when dry applying the *heat paint to seal up your work.
    No ceramic coating or any other direct metal application process can reduce the radiant heat as well as wrapping can.
    If this is your first time wrapping wear disposable cloths long sleeves do it down wind and take a long soapy shower when finished. And the SS straps can cut your fingers like a razor! LOL
    My hedder has been wrapped as pictured since 2003 with 42K miles. Wet and dry weather up and down CA coast HWY 1.
    [​IMG][​IMG]
  10. ColinGreene
    438
    293
    Orange county Ca
    header.
    Alice, your having radiant heat problems with the Mynes header?
    Did you remove all of your stock heat sheilds?
    How odd, I dont have any of that with my header
    maby that header routes closer to the firewall?
  11. AliceCooper
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    All my stock heat shields are still in place,but once she is warmed up I get heat from the vents. Does not bother me that much the wife doesnt like it,but then again its not her car :D
  12. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
