Engine Drivetrain 1st Gen Cooper S Helix Wildebeest TurboKompressor Update
Discussion in 'Tuning and Performance' started by Helix Wildebeest, Oct 9, 2012.
  1. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    No, I mean between the front vs rear mounting, just wondered if you could tell the difference or not?
  2. Helix Wildebeest
    Helix Wildebeest New Member
    Feb 29, 2012
    33
    54
    I did a rear mount just to do it. I also used a turbo that I had laying around. Neither prooved to be beneficial. Keeping the turbo next to the head and reducing system volume is always more efficienct. I converted to a more conventional cast manifold and a properly sized turbo. Boost response is increased incredibly (rear mount =4500RPM spool, conventional = 2500RPM spool).The current setup is superior and doesn't require an electric oil return pump (which will fail).
  3. Chase
    Chase New Member
  4. Helix Wildebeest
    Feb 29, 2012
    33
    54
    The Wildebeest Saw Jesus to get a head. Long story short. Don't port your own head without knowing where the coolant jackets are. I had a crack in my Cyl 1 and Cyl 2 exhaust ports that were leaking coolant into my exhaust ports and cylinders. I finally found it and ended up replacing the head with Jan's Jesus head. All is good in life now.
