2nd Gen R55 Clubman HELP!! CEL on a 2012 Clubman S @ 11,000 miles...
Discussion in '2nd Generation: 2007+ R55 through R61' started by HurricaneDave, Oct 15, 2013.
  1. HurricaneDave
    HurricaneDave New Member
    Apr 9, 2012
    99
    34
    Tellecommunications Engineer
    Ball Ground, GA
    #1 HurricaneDave, Oct 15, 2013
    2012 Clubman S with just over 11,000 miles is throwing a CEL
    Current mods include BSH OCC only
    Codes:
    P0116 - Coolant Temperature Sensor rationality Check
    P0118 - Engine Coolant Temperature Circuit High
    P0128 - Program map thermostat: Sticking in open position
    B2AAA - No idea...?
    P173B - CAN Engine Coolant Temperature Invalid
    Any ideas or advise would be appreciated. Car is running fine and nothing feels or looks out of place at all. Checked all sensor wires and connectors, checked OCC is free flowing/not clogged when disconnected, all fuses look good... really stumped here and waiting for the dealership to call me back to schedule an appointment.
    I am curious if I should be driving the car while throwing these codes (have only driven it a handfull of short trips just to get up to operating temps in the past week since it started)...
  2. DneprDave
    How is the coolant level?
    Dave
  3. HurricaneDave
    Apr 9, 2012
    99
    34
    Ball Ground, GA
    Coolant level is right in spec... caps are all tight...
  4. Savvy
    You're still warranty. Schedule an appointment. Did the 2012s come with roadside assistance as well? If so, you're covered for the tow too.
  5. Dave.0
    I would take it t the dealer to fix for free and get a free loaner.
  6. HurricaneDave
    Apr 9, 2012
    99
    34
    Ball Ground, GA
    Yea I am taking it to the dealer tomorrow morning but wanted to make sure it would be ok to drive the 40 miles to the dealer as it is. The dealer said to just drive it.... so that is what I will do...
    It did come with roadside but the dealer said they want me to just drive it in so I made him write that on my account and send me a copy just in case this turns any worse on the drive tomorrow.
    They only have 2 loaners apparently and they are NEVER available.
    As usual Thanks again for the info!
  7. ljmattox
    ljmattox Active Member
    Dec 28, 2011
    223
    123
    IT consultant
    St Louis metro USA
    Many/most 2012s got their coolant sensors replaced via a MINI campaign. Mine did, at first service (15k). It hadn't caused any issues...
  8. HurricaneDave
    Apr 9, 2012
    99
    34
    Ball Ground, GA
    Took it in this morning and coolant sensor had failed and will be replaced under campaign. Waiting for an update on the stuck thermostat and other codes.
    Will update once I hear back.
    They were out of loaners and gave me a Ford Fiesta rental on them... I MISS my MINI!!!!!
