Brakes Wheels 2nd Gen Tires Help figuring out elusive R53 brake problem
Discussion in '2nd Generation: 2007+ R55 through R61' started by Tom2112, Feb 9, 2012.
  2. Tom2112
    Tom2112 New Member
    Mar 16, 2010
    36
    Stig Substitute
    Sharon, PA
    Thank you very much!
    I'm gonna talk it over with my mechanic and I may just gamble on a new caliper - after of course, checking the master cylinder for leakage.
  3. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    Before taking a gamble on a stuck piston, disconnect the P-brake cable, try to push the cable inward and pull out, if the cable will not slide within the housing, it has a kink. A stuck rear piston or P-brake cable won't result in a mushy pedal, that's another issue.
  4. BThayer23
    My master cylinder failed at the track a couple years ago. It was dripping fluid into the driver's front wheel well. Easiest way to diagnose is to turn the car on and stand on the brake pedal. It should go down and stop. If it drops all the way to the floor with continuous pressure, you probably have a leak. The master cylinder is located roughly between the intake and the windshield on the driver's side, silver-colored with thin pipes coming out. Leaks usually drip down into the well below.
    Keep trying, there is a solution, you just have to find it. I thought my whole car was screwed up for 4 months, couldn't figure out why my pads were squealing so bad. Turns out I had a different type of brake pad on the right side of the car vs the left side, forgot to keep things straight when I was changing pads. You'll figure it out.
  5. Minidave
    4,618
    He may have a master cylinder problem too, but a bad m/c will not cause only one pad to wear out on one caliper and the other look like new.....
  6. BThayer23
    Right. I'm just trying to suggest a diagnostic procedure. A bad m/c would cause a squishy pedal, which was another symptom mentioned by the OP.
