1st Gen R53 Cooper S [Help] Identify this engine rattle
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by melvinyip, Aug 16, 2015.
  1. melvinyip
    melvinyip New Member
    Apr 26, 2015
    19
    Hey guys, I'm in real dire need for some technical advice. I've been having this issue on my cooper S R53 for a couple of months now. It's some sort of a rattle noise coming from the left supercharger horn or somewhere down below. Noise would persist for the entire drive but more prominent during cold start. I've replaced timing chain tensioner but to no avail.. Next plan would be to remove the supercharger to check on the PTO / refill the oil. Fingers crossed
    Video link
    -cooper s r53 2006 checkmate edition
    [ame="http://youtu.be/0u5SA5WcreU"]Cold start noise mini Cooper S r53 2006 - YouTube[/ame]
  2. sethat46
    sethat46 Well-Known Member
    Apr 25, 2012
    1,560
    413
    Financial Sales
    Ohio
    Belt tensioner, idler pulley, timing chain tensioner, or supercharger. Just some ideas of the usual suspects.
  3. MCS02
    6,317
    Welcome to MA!
    What sethat46 said. I would start with a new belt, belt tensioner and idler pulley first. Also check your crank pulley, make sure the rubber does not have any cracks in it.
    Some people change the belt and tensioner once a year.
  4. MCS02
    6,317
    Is it the stock supercharger pulley?
  5. ZippyNH
    Welcome to motoring alliance!!
    Like I said in your twin post on NAM...welcome to motoring alliance!!
    Push in your clutch....and see if it goes away...
    A throwout bearing rattle can sound like it is coming from the SC area...
  6. wmwny
    4,040
    2,242
    Welcome to M/A! What they all said....
  7. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    even if you change the tensioner, if the guides are shot you have no hope of getting it to stop.
    Run the car at idle with the belt off see if the noise continues, if so it would be a internal problem.
    While you have the belt off, spin check all the pulleys.
    Make sure if you run the car with the belt off, you have a pin through the tensioner strap to keep it from touching the crank pulley at all.
  8. Firebro17
    Really Big Crickets.
  9. MCS02
    6,317
    yes what he said!!
  10. melvinyip
    Apr 26, 2015
    19
    #10 melvinyip, Aug 17, 2015
    Thank you for all the suggestions guys!
    Will check it out and update here on my findings.
    Really hope my supercharger is not fcked up in any way ��
    By the way, mine is a Aisin automatic r53
    Supercharger is stock cooper s, yet to change until I've gotten this issue fixed.
    I've gotten a sets of screamin demon coil packs as well as 17% reduction pulley from WMW, grs inter cooler, waiting to be installed..
    I'm from Malaysia and Ive just gotten my car for about 3-4 months now
  11. MCS02
    6,317
    Get rid of the screamin demon coil packs unless you want to take the chance of frying your ECU. The OME one is good for big HP numbers.
    Your Mini looks good.
  12. melvinyip
    Apr 26, 2015
    19
    Thought I'd update on this. I've did a supercharger snout rebuild. Found one of the bearings to be in rough condition. Swapped all 3 bearings out, new seal and new coupler. Knocking snd grinding Sound reduced significantly
