1st Gen R50 Cooper HELP!!!!!!!!!!!!!!
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by M1N1, Apr 5, 2015.
    Check to make sure the caliper is not dragging.
  2. ZippyNH
    They seem to take a few miles too mate to rotors....but they get better...
    I think it took a couple thousand miles of mostly highway usage on my car to get a good feel with new rotors... Guess I could have used them more to accelerate making the feel better, but once done, they feel pretty similar to the OEM pads that came off my gen1.
    But my front wheels are cleaner than my rears now...
  3. ZippyNH
    Second the draggy caliper....
    Had to replace my right rear when my brakes were done last ..check the cable first, but I bet it is sticky internally.
  4. mrntd
    Great to here it is all fine now. :Thumbsup:
    Come on down and see us sometime. Or you could meet up at Mid-Ohio in June for the vintage race.
  5. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    #25 M1N1, Apr 7, 2015
    I checked the steering/braking (hands off wheel, straight and true) as I drove home from work last night. When I have time tomorrow, I will get the wheel off the passenger side, and have my wife pump the brakes while I watch the action of the caliper, etc. I plan on flushing the brake fluid, again when I have time. Work tends to get in the way of the fun stuff :cryin:
    mrntd. I am hoping to visit for coffee and donuts, put faces to avatars/usernames/cars, MINI talk, etc. Again, work tends to scupper my plans. I am scheduled to work every other weekend (automotive stamping plant), and I work second shift so I don't get home until about 1 am. It is about a 3 hour drive down to the Columbus area. Thinking of taking a half day vacation on a Friday night when my weekend off coincides with coffee and donuts.
  6. M1N1
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Is it worth installing a guide pin upgrade (bronze bushings, new pins) in place of the OE set up?
    Yes.
  8. ScottinBend
    Yes, just make sure to service them regularly. I do mine each spring/fall with my tire change.
  9. ZippyNH
    IF you don't mind cleaning and greasing them yearly....I'd go more that way with a tracked car...
    Better feel...but more MX..
  10. ScottinBend
    Takes about 10 mins to service per caliper.
