HK radio sizzle
Discussion in 'MINI' started by docv, Mar 31, 2014.
  1. docv
    docv Well-Known Member
    818
    280
    moble auto paint tech ( PTU )
    Central Missouri
    Ok I need some opinions, My HK sound system now has a sizzling crackling sound that is extremely loud. It does it when motor is running, when the engine is off stereo sounds good. The crackling does not increase with rpm's it remains constant.
    So what do you think, plug wires, coil, or something else. I want to get it corrected before I head to Fontana.
  2. ScottinBend
    Check the ground on the headunit first.
  3. Dave.0
    Yup ^ Ground on HU and also check your battery ground and motor grounds.
    Also check the coil buy sanding down the ends to get rid of any rust. Pay attention to the two back ones.
  4. docv
    818
    280
    Central Missouri
    Thanks, will try all the above and let you know.
