Hoosiers 225/40r17 are 9 inches of tread
Discussion in 'Autocross' started by jetsr6, Oct 21, 2017.
  1. jetsr6
    jetsr6 Member
    Aug 31, 2017
    95
    79
    Driver
    Loganton, PA
    Yep and they fit, kinda. Only have 2 more weekends of autocross left. Can't wait to test these out.
  3. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    A6s?
    I don't know how stiff your suspension is but I'd be willing to bet you are gonna get some rubbing on the outside tire during turn-in. Keep an eyeball on those fenderwell guards.
  4. jetsr6
    jetsr6 Member
    Aug 31, 2017
    95
    79
    Driver
    Loganton, PA
    I actually rubbed the inside rears. Ended up with 11mm spacer in the rear. There A7’s
  5. Redbeard
    1,636
    398
    How did you rub the inside rear tire on turns? The suspension in that corner would be under less load than driving straight.
    Did you mean outside rear?
  6. jetsr6
    jetsr6 Member
    Aug 31, 2017
    95
    79
    Driver
    Loganton, PA
    The inside of the tire rubbed on the trailing arm. My wheels are only 8 inches wide and I probably should have gotten that 9 inch wide wheels.
