How I Clean Wheels
Discussion in 'Detailing' started by Batrugger, Jun 17, 2011.
  1. BlimeyCabrio
    WD-40 as a relatively gentle solvent/cleaner is an old detailer's trick. Been using is as my primary tar remover for several years with no problems - ever. No damage to paint, etc. Mostly Kerosene in a spray can...
    A good washing with soap and water removes all WD-40 residue. Whether on brakes or anything else. While I wouldn't drench my brake rotors and pads with it on purpose... I also don't fret if I get any on there... I just wash it and it's gone...
    Works really well on globs of tar that you often get on the inside of your rims, too. Sometimes takes a few sprays with a little soak time in between to break all that up.
  2. DneprDave
    WD-40 isn't a lubricant, it's a water displacing coating. It evaporates in a couple of days. Hose your brakes down all you want, the lubricating properties of WD-40 are short lived.
    Dave
  3. ScottinBend
    Exactly......a very light oil with kerosene. Very easy to wash, and even burn off. LOL
  4. Pmini
    Pmini New Member
    Jul 31, 2011
    Marketing
    South Florida
    Great suggestion, will certainly try it.
  5. CHKMINI
    Exactly!!! In fact the name" WD- 40" is derived from it's description when originally specified by the military....Water Displacement 40.
  6. Metalman
    Yeah.... And the 40 stands the 40th recipe that finally worked....
    So stay away from WD-39.....:D
    Now then, what about 3 in 1 lubricant.... Nah, don't want to go there.....:D
    I'm waiting for WD-41..... :ihih:
