How to Destory a Thread ...was...The Truth About Valvesprings!
Discussion in 'Politics and other "Messy" Stuff' started by Dr Obnxs, Sep 21, 2010.
Thread Status:
Not open for further replies.
  1. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    #1 Dr Obnxs, Sep 21, 2010
    Over the last few months, there have been some discussions about valvesprings, much without data or hard information. So anyway, I thought I'd share and article and an offer to get the ball rolling here.
    First some background. I'm a physicist, so I'll start from springs and masses. The point of a valve spring is to keep the valve following the cam profile throughout the RPM range of interest. Pretty simple, yes? So then why are springs rated at things like 80 lbs seat pressure closed, and 200+ lbs seat pressure open to just keep a little valve that weights at most a couple ounces where it's supposed to be? Don't those numbers sound excessive?
    So, let's think about the valve train. There is a camshaft with it's lobes. There is some form of rocker that rides the lobes, pivots somewhere, and presses on the end of the valve. This is for overhead cams (standard V8s have lifters and pushrods, but the idea is the same). What pushes back on all this stuff to keep it from rattling is the valvespring. It sits on the top of the head, and is kept in place by the retainer and lock. So this spring has to be able to push all this hardware back against the cam lobe.
    The real killer hear is that as things go fast, it's not the basic static weight of the parts that comes into play. The spring has to overcome the inertia of the valve, the retainer, the lock, the rocker, as well as the spring (or springs) themselves. At 7000+ RPM, this takes a lot more force than is needed to just hold the parts against the force of gravity. Thousands of times the force. It can get pretty staggaring.
    So, what does all this matter? For our Tritec engines, the choices for valvesprings have, until recently, been pretty limited. Every head I've seen has used some form of convetional spring. No one was offering beehive geometry. Some used Ti retainers, some used the stock steel ones. Some used single springs, some double. Some of the springs needed pocket work cause they were too long, and some needed spacers cause they were too short. None of this is bad per se, but it's all the consiquence of using parts pretty much designed for other applications and used because they were "close enough".
    So, what's different? Well, nothing really. The PAC Racing Springs in the NS Valvespring and Retainer kit aren't custom for the MINI. They are, in fact, "close enough" springs found in the PAC spring catalog. What is different with the set is that the retainers are custom to the MINI so that a spring that is a touch too long can be used without machining a deeper pocket. What is new is that this is the first spring set for the Tritec that uses ovate wire (oval spring wire) and beehive geometry. The result of this is a lower mass spring and retainer set that has reduced harmonics compared to conventional springs.
    Now, in some of the PMs that I've gotten from people, some who were not really happy when about the debate about springs, there was one quote that stuck in my mind: "You know that no one can feel the difference between one valve spring and another." And to be honest, I think that if the springs are properly selected, that may even be true. But we have a group of people in MINIs who are pushing ever higher RPM, and using aftermarket cams with more lift and aggressive profiles (this is called "ramp" to the cam guys). The faster the ramp, the faster the acceleration of the parts. Agressive ramp is the key to the NS cams benefits with lower overall lift (but that's another story). Anyway, we're demanding more and more out of the valvespring and retainer. And some are doing this with stock, or stock equivalent springs (for example the Cosworth single spring setup was a stock-equivalent spring. Same strength as the stock, just more consitent in specifications.)
    Think this is all just marketing BS? Well, this is why I love Hot Rod Magazine. Sure it caters to the V8 Big Block crowd and American chassis and the like, but engines are engines, and they do some really great tech articles. The November issue was no exception and they have this article All About Valvesprings. I scanned it for your reading pleasure. It's seven pages (a lot for a mag article) and the high points of it are:
    • In the past, valve train performance was limited by spring technology.
    • Times have changed, and new geometries and materials have come into play.
    • One V8 engine had significant high RPM HP increases when going to a SOFTER beehive from a dual spring set up!
    So read away, and learn from the experts......
    I've also got an offer to those that are interested in our spring and retainer set. The set retails for $385 on our site here. I want to get some of these kits into the hands (and onto the engines) of those that think they can benefit from them. So for the first 5 kits that are ordered in this offer, I'll let them go for $335 a set. To get this price, you have to do PayPal to [email protected]. If you want to do a telephone credit card transaction, e-mail me at [email protected].
    If you have a stock motor, no tune, no cam, no nothing, these aren't for you. If you have a raised red-line and/or aftermarket cam, these may be just the ticket for really getting all the HP your engine has to offer as you bang the rev limiter!
    Matt
  2. JCC
    JCC New Member
    Dec 15, 2009
    190
    Installation Manager
    Sachse, Texas
    VERY nice! Thanks for posting. :Thumbsup: Not that I'm modded in any way except a short shift kit and auto up circuit, unfortunately.
  3. jiminni
    jiminni Well-Known Member
    262
    Ca.
    #3 jiminni, Sep 21, 2010
    Nice info. Matt :Thumbsup: I did notice a difference at high RPM after my set was installed. Where my car seemed to, well not to say it bogged down up there, but after install there was a much better feel all the way to my 7500 redline.
  4. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Because there are so few of these sets running out there...
    I don't have good data sets of before and after. What I found so surprising in the article was going from a 523 lb open dual with damper to a 318 lb open beehive gave almost 40 HP to the engine at 6800 RPM. While it's 425 HP 406 CI small block chevy, that's still a heck of a lot of "found" hp for just going to lighter springs and retainers. And as a percentage of weight, it's even less when one considers that this has lifters and pushrods! Anyway, that was quite the eye opener for me.
    I'm looking forward to installing these on my car. But every time I get ready to do it, I send a spring and retainer out so that vendors and head builders can check them out....
    Anyway, if you're doing a head, talk to your head builder about these. If you build heads and want to use these, get in touch with me about using them for your builds.
    Matt
  5. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
  6. Jan
    Jan Well-Known Member
    377
    382
    are you suggesting that Cosworth put springs on the car that are NOT able to rev to 7500?
  7. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #7 Nitrominis, Sep 22, 2010
    As per COSWORTH Engineering Development Department Mini Cooper engineer for canceled project. They used a single spring using the specification from an oem MSC spring and out sourced for production. Which later became a boxed COSWORTH spring. On the Dual spring COSWORTH head offered either Ferrea or Super Tech Spring.
    The spring claims are based on a single spring capability alone. Not the application of the MINI. See all the suppliers information.
    The liberties of advertising clarity is never certain unless exactly stated.
    COSWORTH never gave a relative operating range of their supplied completed head. I believe if you look at the ad it said something like spring capable of going to 10k rpm? Which really in a technical sense did not pertain to the overall head but good to advertise?
    Information obtained by me talking to COSWORTH USA.
    Cosworth USA
  8. Jan
    377
    382
    so you are implying that Cosworth is lying?
  9. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    No matter how you slice it....
    lower mass valve springs and retainers can control valve motion to higher RPM because they weigh less. This means more of the spring derived force goes into moving the valve and valvetrain that just controlling the mass of the spring themselves. That's just fact.
    What really is key here, and not really in play because no one has good data, is how do all the springs available work with the different cams, different valves (with different mass) and the like. I wish I had a Spintron machine to do it all and generate the data set.
    I was surprised that no pissing contest had started up yesterday, but I see it wasn't a question of if, but when. Oh well.
    Anyway, I hope those that were curious about valvespring technology learned something from the article I posted. There is also a perfect example there of springs that in a given app (that they are sold to) spin up to a given RPM but aren't really doing the job at that RPM that a better spring can do. What I found so interesting on that example was that the conventional dual spring was so strong that it was actually bending valvetrain components (more torque at low RPM), yet didn't have the strength to control the valves at the high RPM that the engine was designed for. No, that wasn't a Tritec, but it's a real example of how a lighter single beehive can do a better job than a heavier, stronger dual spring set up. This is a perfect example of how lighter valvespring/retainer combination can do more of what one wants from it while providing less stress and wear on a valvetrain.
    Take from it what one wants.
    Matt
  10. Jan
    377
    382
    No one is starting anything. I'm just surprised that Jim would say something of this nature when he has sworn numerous times that Cosworth knows what they are doing. Seems kinda odd don't you think?
    As for running different springs etc , I saw 40+hp differences on my big block back in the day but for a Mini I highly doubt measurable gains anywhere. As you noted, if you had a way of testing it I'm all for it. I'm always looking for the better products. I have yet to see anything "for sure" that has "proven" to be better beyond a doubt.
    Reading some article that pertains to a different engine is pointless in my opinion. Food for thought.
  11. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    WTF?
    So, for those that don't know anything, or very little, about valvesprings you think an article about the technology that explains the pros and cons has no value? That's just silly. Best (and real) criticism is that while the examples are illistative, we don't know how much they bear on our engines.
    Read the article. See how builders of engines use technology to create better motors for people. See how they have found different technology to provide real world gains. It's usefull. The article talks about beehive springs, oval wires, dual spring setups with and without dampers and triple spring set ups. The dangers of going to deeper pockets on heads to accomidate longer springs. Retainer to valve fit. Ti retainers. Exotic valve material. Valve locks. It illustrates these concepts with engines that are of interest to the market market of Hot Rod. (V8s, that's the only thing that has no direct bearing on MINIs.) It's a good article. Go ahead and read it and find what you think is useless and post it up. It's not going to be a very long post.
    Matt
  12. Jan
    377
    382
    Matt, I think it's a great article about V8s and what they have seen. How exactly this info translates to our Mini's has left much to the imagination. It's like telling everyone they need to drop their factory oil pump because a dry sump's better. Is it really needed?
    I'd be much more impressed if you took the extra hour to do a before and after dyno on Jimini's car. We all know about butt dyno's and how they relate to Mini topics.
    Then again it's much easier selling products through theory instead of performance.
    As I mentioned earlier I AM LOOKING FOR THE BEST PRODUCTS OUT THERE......I just want some proof it works on OUR car, not in some engineer's head
  13. Thumper460
    Thumper460 Active Member
    May 26, 2009
    559
    94
    United States Navy ..Retired
    Good Article. Dr O. !!
    As the camshafts become a bit more radical and with more aggressive ramp angles, it is good to know there will be a spring on the market that will carry the higher lift and duration numbers.
    Valvespring is a over missed performance item.. some used to feel if the cam didnt stack the spring, you were good. Not really knowing that the pressures needed to keep the valve closed ( to stop seat bounce) and the power loss in harmonic vibrations was something to be considered also.
    The Conical/ Beehive has been out for YEARS on the other Performance applications, the Conical design has proved its self many times over. As a fact some OEM cars also use the Conical design.
    Good info!
    Just me........................................
    Thumper
  14. Jan
    377
    382
    what I found fascinating was the stock JCW Head on the Grand Am cars had no issues with the Newman cam , rev'ing it to 7500. Not one single valve spring failure and those engines run near redline for almost 2.5hrs at a time. Much more abuse than what a street car will endure........ hard to doubt actual performance vs "engineered" theory....... just my .02 until it's proven otherwise
  15. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Jan, I totally understand what you are saying
    but even you would grant that there is a HUGE performance envelope between running optimally and total failure. So, the very same "proof" you state (It's run at that RPM and hasn't failed) says nothing about if it's working perfectly at those RPM.
    Matt
  16. Jan
    377
    382
    true enough, but based on data logs and dyno graphs it's NOT floating the valves. So at least I have some form of testing done. Like I said, some real testing done on the springs besides someone's butt dyno would be fantastic.
    I can tell you we went 2:10 with the stock head at Watkins Glen running the guts out of the car. It must have working pretty well:devil:
    3-5sec faster than the year before and that valvetrain was on ferrea:devil:
  17. jiminni
    262
    Ca.
    LOL! My car revved just fine to 7500 before the NS springs, but I notice an improvement after install :cool: So here we are again with the Cosworth BS :prrr: We all know Jan that you know better than Cosworth :lol: :lol:
  18. jiminni
    262
    Ca.
    In my opinion your race products don't mean crap for our daily street driven cars :idea: To quote you from a sewing forum, "The rotrex has an advantage as the torque is up high in the power band so it's easier to drive".
    :lol: What kind of BS is that? No bottom end has an advantage? Whatever dude :crazy:
    Food for thought
  19. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    #19 ColinGreene, Sep 23, 2010
    not so its easyer to drive but easyer to get the torque to the ground.
    who says the race products don't mean anything for the street, i daily drive my car with a "race" cam in it. works fine.
    everyones diffrent. I think the point that was trying to be made was that you had a cosworth head and swore by it now your saying that these springs are a god send
    Thats pretty much saying that the cosworth guys had no idea what they were doing right?
  20. Jan
    377
    382
