1st Gen R53 Cooper S I present to you the first ever R53 Active Aero Air Brake
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Helix Wildebeest, Sep 27, 2013.
  1. rkw
    rkw Well-Known Member
    443
    Does it go up faster? I count almost 4 secconds to raise fully. If braking hard at speed, it needs to snap up immediately to be effective.
  2. silky
    silky New Member
    Oct 12, 2009
    1,086
    51
    Of course you'd need to map speed of deployment, brake actuation pressure, braking duration, vehicle speed...or you could end up looking silly in morning rush hour...
  3. lucas0292
    lucas0292 New Member
    Jul 10, 2013
    16
    Kansas City
    Could you give a little more information on the build? I'm assuming you did this yourself. I'd really like to do something like this to mine!
  4. Savvy
    saw you running in the wild near PHL today... very cool to see in action (sort of).
  5. Sneedspeed
    Sneedspeed New Member
    Jul 16, 2009
    165
    56
    Racing cars
    Pfafftown NC
  6. Helix Wildebeest
    Helix Wildebeest New Member
    Feb 29, 2012
    33
    54
    #26 Helix Wildebeest, Sep 30, 2013
    These were the quickest option for Linear Servos that I could find. I got 6" of travel with 25lbs of lifting force. They were suppose to travel 2" per second, but proved to be a little slower. I suppose I could reduce the travel length with shorter units and change the axis for quicker action.
    I cut and bent the aluminum and brackets myself. The airfoil is a Mugen unit for the Honda CR-Z. It was the shortest width that I could easily find for the cost. I pretty much designed it as I built it with some idea of how to make it work.
    The actuation is a double pole NO/NC 10amp 12v relay. I wired the relay so Normally Closed was wired to the actuators for the close position. When the relay was signaled from the brake light, it would flip the poles so that Normally Open would reverse the polarity and open the actuators. Pretty simple.
    [ame="http://www.youtube.com/watch?v=SGtXqczNSBA"]http://www.youtube.com/watch?v=SGtXqczNSBA[/ame]
  7. Helix Wildebeest
    Feb 29, 2012
    33
    54
    "Sort of" :wink2
  8. Metalman
    Good stuff....
    Engineering in action...
  9. Savvy
    Well, creeping up to the intersection near the Simeone museum, and seeing the blue blur go rolling past with airbrake pretty much deployed didn't allow for much "action" time.
  10. TheModFather
    Why dont you just tell M7 and Alta how to copy it... :(
  11. Helix Wildebeest
    Feb 29, 2012
    33
    54
    :ihih:
  12. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
  13. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    970
    732
    training specialist
    Maysville, North Carolina USA
    It would look cool on the GP :ihih:
  14. Justa Jim
    I had the hatch open yesterday when I realized it would make a great air brake. Just put the actuators on it. :D
  15. Locust
    Locust New Member
    Dec 20, 2009
    I think that is the coolest thing I've seen in a while! Great job!
