Brakes Wheels 2nd Gen Tires i prolly chose the wrong tire!
Discussion in '2nd Generation: 2007+ R55 through R61' started by genik, Mar 9, 2017.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    I've just fitted on my R56S the Dunlop Sprt Maxx RT run flat tires and I must say that they are nothing like the ones I had before (CONTINENTAL conti sport 03 run flats). The Dunlop although are more comfortable and silent on the road it seems that on hard corners they kinda slide sideways more than the Continental!! I don't know if this can be hazardous on more extreme driving but it certainly gives a pretty scary feeling!
    Has anyone had a similar experience?
  2. whaap
    whaap New Member
    Jan 10, 2014
    515
    313
    Tucson, Arizona
    I can't personally say but I can say I've never read any thing good about run-flats.
  3. Dave.0
    Knowing how you post and the questions you ask...."i prolly chose the wrong tire!" is not a surprise.
    Run Flats SUCK.
  4. genik
    genik Member
    Feb 20, 2012
    402
    19
    speak of the d3vil
  5. Dave.0
    Devil ? :devil: Yes , and speaking of you.....more poor decisions.
    I am really surprised you did not start a "what tire should I buy thread".
    Then again you would not listen and end up in the same place you are today with crappy Run Flats. :lol:
  6. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Ditch the run rocks for a reputable well reviewed tyre and the sliding will go away. If you do slide on some good performance tires it's (intentional I hope) predictable and controllable. Run flats just under-steer like a mother.
  7. genik
    genik Member
    Feb 20, 2012
    402
    19
    You wouldnt know how to help simply because you're too old fashioned... in the mind.
  8. Dave.0
    Qik, you are talking to a wall. He will not listen.
  9. Minidave
    Do you have the right tire pressures set?
  10. genik
    genik Member
    Feb 20, 2012
    402
    19
    The Continental Sport3 were run flats and didn't have that issue!
  11. Dave.0
    Then return the crap you got and buy them. Why did you change?
    Different tires react differently. DUH :frown2:
  12. genik
    genik Member
    Feb 20, 2012
    402
    19
    Yes 2.5
  13. Dave.0
    Remember people he is in Greece. "The Country"
  14. genik
    genik Member
    Feb 20, 2012
    402
    19
    I see you started your racist approach when in lack of arguments or any help advice!
    My 2 cents worth. If you chose runflats than yes it's the wrong tire.
  16. MCS02
    Yea it may be to late but runflats are no good.
  17. genik
    genik Member
    Feb 20, 2012
    402
    19
    Please explain further, why is it the wrong tire?
  18. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Those are the tires that were on the car when I purchased it and I had that issue. After a couple laps on a track it felt like I was driving on gravel they slid so bad.
  19. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    So you're a Turk? :cornut:
  20. Zapski
    I know this is a silly question but have you had at least 500 miles of driving on the tires before pushing them? The releasing compound takes some time to wear off new tires.
