2nd Gen R56 Cooper S I think I jinxed myself......
Discussion in '2nd Generation: 2007+ R55 through R61' started by KittyMini, Oct 20, 2011.
  1. KittyMini
    KittyMini Club Coordinator
    1,183
    I don't know much about clutches so I'm posting this for you all:
    So I noticed the other day a noise while I'm parked and the car is running. It's a ticking sound, but not the normal one the car has always made. It's slower and deeper than the "diesel" noise. It didn't notice it the next time I drove, so I dismissed it.
    Well, I heard it today while I was waiting a moment for my car to heat up a bit before driving home from work. Since these clutch topics have been forward in my mind, I started playing around....
    Here's what I found:
    The noise stops when I press in the clutch pedal. But when my foot is off of it, the noise returns. It's not real loud, but noticeable.... I'm pretty observant with my car's noises.
    Could this be something with the clutch? The throwout bearing? Is it something I should wait on, or should I have the dealership look at it? I will be taking it in soon anyway for regular service/maintenance.
    Thanks for the help/advice.
    Mine has made that sound for 50,000 miles or so. I believe it is a sound that the dual mass flywheel sometimes makes. My clutch functions fine so I've learned to ignore it. If you are still under warranty maybe you can get them to replace it, if not turn up the radio. :wink:
  3. KittyMini
    1,183
    Oh, did I mention I have an R56? :mad2:
    I really don't remember hearing it before? :confused5: But it is driving fine.
  4. Dave.0
    Sound like you may now have Stephs clutch issues.....:incazzato:
    I really hope not. :fingerscrossed:
  5. KittyMini
    1,183
    Maybe- seems like the only real way to get rid of it is to get a nice aftermarket set-up, which, I plan on if this ends up being an issue.
  6. Dave.0
    Get your freebie clutch from MINI now
    Then save up for OS Giken clutch and LSD.
    YEAH BUDDY!
  7. KittyMini
    1,183
    Yeah buddy is right!!!!!
    :Thumbsup:
  8. countryboyshane
    countryboyshane New Member
    Jul 23, 2009
    202
    Diesel Engineering
    Bloomfield Hills, MI
    If you're still under warranty you'd be silly not to bring it in for a dealer check up. I hope it's nothing too bad as a whipping in a new clutch is damn expensive:cryin:
  9. KittyMini
    1,183
    I'll have the dealership check it out..... I'm still WAY under warranty :Thumbsup:
  10. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    Why are you doing that? You are just pouring fuel down the pipe. Start her up, drive away easy and when the temp guage reaches optimum, THEN drive it like you stole it. If you are waiting for the heater to come to the party, well, thats what hats, coats and mittens are for.
  11. KittyMini
    1,183
    I'm waiting for the rpms to settle, that's all :Thumbsup:
  12. Friskie
    Jul 20, 2009
    1,650
    1,333
    I see. Lull them into a state of complacency just before you stir them into a frenzy. How devious of you.
  13. KittyMini
    1,183
    Oh, I'm devious! :devil:
  14. KittyMini
    1,183
    Well, Artemis is home....
    The result? They said the noise was normal for that type of flywheel.
    Ah, ok?
    I'm not worrying about it..... if it blows up on me and they don't cover it, I'm just going aftermarket and be done with it.
    Oh the famous "they all do that". :lol: They go to school to learn to say such things with a straight face.
    For what it's worth I think it will be OK. Mine has made noise for many miles & everything is fine.
  16. KittyMini
    1,183
    Yeah, what BS :mad5:
    Whatever- like I said- if they don't cover it when it gives up I'm going aftermarket- already planning on doing an LSD at the same time :ihih:
  17. Crashton
    Mine has been making an odd noise (flywheel) for 50,000 miles or so. I'm sure your will run a long time too. My MINI already has an LSD. :)
  18. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Mine has a factory LSD but that was exactly the noise I heard. Metallic chatter while in neutral and foot off the clutch pedal (clutch engaged) and then it goes away when you push down on the clutch pedal (clutch dis-engaged). The reason it got my attention in the MINI is that the dual mass flywheels in the 2006-2008 350Zs (like the one I had) had a tendancy to go bad and chatter like nervious chihuahua in the snow (like mine did). The net result is poor engagement and premature wear of the clutch disc.
    They (MINI if Monrovia) tore mine down and found the funny wear on the clutch and the dual mass flywheel was flexing too far and it was all replaced. (I think you've seen that thread already. Post replacement no funny noises or engagement issues.
  19. KittyMini
    1,183
    If the noise gets worse/more permanent I will take it back and insist they tear it open.
  20. Thunderball Kaboom
    Thunderball Kaboom New Member
    Aug 17, 2010
    49
    I am the Coordinator for a program that provides h
    Live and play in Central Phoenix - Camelback corri
    My clutch began to whistle like a teapot, first only when in motion but later on when idling as well. Just touching the clutch made it stop. It was diagnosed as a bad throwout bearing. Fortunately, the shop had a 40% off promo going on, so it only cost $900. Sadly, it's started again 6 months later - going in tomorrow for a warranty review (or trade in if they say it's normal!).
