Suspension Brakes IE fixed camber plate bearing seals?
Discussion in 'Tuning and Performance' started by grodenglaive, Mar 24, 2012.
  2. Metalman
    Chuck, there is a vertical adjustment screw accessible at the very top of the unit that are recessed into the front bumper.....:D
    That is good to know. Thanks...
  4. Metalman
    ^^^ Hey Chuck, the back side of that piece of cardboard is pristine.... Want to shoot some fog lights at it????:D
    I think mine are aimed OK. I'm on stock ride height with a slight list to the drivers side. :donut1:
    I thought your MINI may have needed that adjustment.
  6. Metalman
    Yeah, sometimes too many donuts will do that....:drool
  7. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    Yup, found the screws, turned them, nothing happened - they just seem to spin freely. Doesn't really matter anyway, I was just experimenting. Raising the vertical a little had the desired effect.
  8. Metalman
    ^^^Interesting, I turned mine and the cut-off pattern started to move horizontal, I returned the pattern and re-inserted the cover.... Then adjusted my vertical pattern as per the diagram....
  9. grodenglaive
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    this doesn't surprise me - my car seems to contain more "citroen" than most MINIs.:wink:
  10. Octaneguy
    Octaneguy New Member
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    **UPDATE on IE Plates
    Ok I'm going to retract my previous statement that my IE plates were causing premature tire wear. I just got two new front tires as well as an alignment and the shop said I was WAAAAYYYY out of alignment. Anyways, the car drives much better now should be much better. I'm going to get another set for my wifes forthcoming convertible. :biggrin5:
    Richard
  11. Mindspin311
    Mindspin311 New Member
    Jul 13, 2012
    17
    Would someone mind posting pictures of both the adjustment (horizontal/vertical) screws on the headlights?
  12. grodenglaive
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    Hi, here it is.
    On mine the horizontal screw, H was hidden under a plastic plug that had to be removed for access.
  13. Mindspin311
    Jul 13, 2012
    17
