Adding an Image to a post from your album hosted on Motoring Alliance is quite easy. Simply select the image disired from your Album and when that image is opened you will notice two blocks of text at the bottom of the page. Copy the text from the lower one labeled BB Code and paste where desired in the post. See image below, the text to be copied is highlighted in blue.
