Install - Hotchkis 25mm Comp Rear Sway
Discussion in 'Car Builds, Projects, Idea's Experiments' started by InstrumentOfPeace, Jan 25, 2020.
  1. InstrumentOfPeace
    InstrumentOfPeace Active Member
    Jan 10, 2020
    106
    69
    @Dave.0 speaking of which, any pro-tips? Dos donts, how tos... with regards to the bar.
  2. old81
    Well since you did not ask, as mentioned, if on full stiff on a 25, do not lift in a turn, ever! I usually run in the middle since my reaction times have slowed a bit in my 70s. :) . I have run a 19mm and a 22mm in the middle on my 07 MINI, never took the jump to a 25, but gave it some serious though when I was doing some autoX.
    • Like Like x 2
    • Agree Agree x 1
  3. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    Thanks Don! Mind explaining a bit more on the term “lift”?
  4. old81
    Sure! Crashton could chime in too. As I know in his ralleye days he might have expierenced 'lift pucker'
    If you enter a sweeper, or a turn such as a fast on-ramp or a country road turn which is over 30 or 40 degrees of arc under full or near full throttle, lift gradually or reduce your power in a controlled manner, if you lift and cut power to nothing, usually you introduce oversteer where the back end of your MINI swings around and you might back into the barrier, tree or ditch ass first versus a nice graceful transition through said turn, then you can put on power for the rest of your drive. Until the next sharp turn. Wow, run-on sentence, I hope you get the drift.
    • Informative Informative x 2
    • Like Like x 1
    • Agree Agree x 1
  5. MCS02
    No pun intended!!:D
  6. Dave.0
    Nothing to add tip wise other than the very good advice above. Just practice, practice, practice and start simple and learn how the car reacts to different imputes in turns. The best thing you can learn is from seat time, doing it yourself will build your skills and memory.
    • Like Like x 2
    • Agree Agree x 1
  7. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    Haha. Funny!
    I got ya, lift my foot. Check. Thank you. I do take some turns that are sharp in the canyons. Typically I try to brake before then accelerating into a turn (H.S. Drivers Ed?) of course I’ve misjudged plenty & puckered up.
    So calmly & gently counter steer when (if) the back end swings. Check. Check. Noted. ... hmmm like driving in Western PA in the snow.
  8. MCS02
    #28 MCS02, Jan 29, 2020
    H.S. Drivers ed will kill you. I remember being with a friend that in a panic stop kept slamming on the brakes locking up and would let up and slam agin (pre-ABS). I was screaming to stop doing that. When we finally stoped alive, no thinks to him, I asked him what in the H3LL he was doing, he said that what he was taught to do in DR ED. He had no clue what threshold braking was.
    Brake coming to the corner, once you enter the corner keep the speed even till you apex out then start to accelerate. A front wheel drive car can be done a little different but its still to keep the car balanced going in.
    Unless you are on a rally, then its a$$ out all the way around the corner. Chuck can teach that, I am not manly enough for that.:D
    Find a High Performance Driver Ed to do on the weekend. The Porsche and BMW club usually have good ones.
  9. ScottinBend
    Countering oversteer in a FWD car is not easy. Instinct tells you to get off the throttle......you need more throttle in a FWD car. That is why I say keep it neutral with a tendency to understeer at the limit. It is much easier to come out of an understeer unless you have lots of track time to practice. You aren't on a race track.
    The internet is not a great place to learn high performance driving. You need seat time & a safe place to do it. Doing a Porsche club or other track day / drivers school is a very good idea. you will learn a lot. Even auto-x will teach you the benefits of smoothness & car control.
    Please be careful trying to find the limits on public roads. The margins for error can be very slim.
    Have fun be safe. :Thumbsup:
    • Like Like x 3
    • Agree Agree x 1
  11. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    Hmm. This sounds like an amazing next hobby.
  12. wmwny
    4,040
    2,242
    BMWCCA will teach you about all you will ever need to know and usually on a track [aka road course] in a 2-day school with lectures followed by seat time with an instructor. Their schools are based on your ability and the instructor can move you up as your ability improves.
  13. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
    I recommend putting the bar on the lowest setting and get some driving time to experience the change. It's easy enough to change it to a new setting when desired.
    • Like Like x 3
    • Agree Agree x 3
  14. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    I may do that as my daughter rides shotgun (although I don’t speed with her in it :D)
  15. old81
    Going fast is not = to speeding, pick your roads carefully!
    • Agree Agree x 2
    • Like Like x 1
  16. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    That sir, is the voice of wisdom & experience
  17. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    So I took my favorite canyon up to see my daughter on Friday (Father Daughter school dance)
    Taking the turns at a speed I’d normally take them. The primary difference, if I’m not imagining it, is the vehicle seemed to turn smoother with ease versus a “rough” vibration across the vehicle. Dunno if that makes sense.
  18. old81
    With the new bar and fittings, the MINI will feel tighter or smoother, give it. 500 miles and see if it stays smooth. Should not have any vibration unless a suspension componet it loose.
    Enjoy it, try different things.
  19. colinmini
    colinmini Well-Known Member
    441
    Agree with most of the above. Start on softest setting and get the feel of the better rotation of your MINI. The “lift off oversteer” is a very real “bad thing”! Autox courses are a great place to explore you, your driving and car’s dynamics.(slower speeds/yet still at the limits, nothing to hit but cones.). Have fun! But also be safe!
    • Agree Agree x 2
    • Like Like x 1
  20. InstrumentOfPeace
    Jan 10, 2020
    106
    69
    Thank you. I may dial it back a notch. I’m not too wild of a driver but I’m sure in a moment of emergency I may oversteer
    So far so goo though other than the sudden loud as Fck clicking & clacking noise in my trunk.
    I’ve check the swap bar over & over and it’s bolted in solid. Must be something with the trunk latches.
