Suspension Brakes 1st Gen Installing new camber plates resulted in a new problem!!!
Discussion in 'Tuning and Performance' started by panaphobic, Jul 26, 2010.
  1. panaphobic
    panaphobic Club Coordinator
    Jul 19, 2010
    192
    12
    Customer Support
    Tewksbury, MA
    i was expecting that. it's tough to see in the pic but the drivers side seemed to be leaning inward a lot more than the passenger side and the car was parked flat. i'll have to take some more pics later with a ruler when i get a chance
  2. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    Check your lug nuts... Had that one happen to me a long time ago on my VW.
    Funny noises, odd handling. Checked everything but the damned lug nuts. Wheel came off and THEN I knew... :cryin:
  3. panaphobic
    Jul 19, 2010
    192
    12
    Customer Support
    Tewksbury, MA
    Yeah that was the first thing I checked lol. And Way from Way Motor Works thinks that my suspenion might be old and sagging. I might just scrap the IE camber plates and get new suspension instead. It might just be a better solution to my problems.
  4. panaphobic
    Jul 19, 2010
    192
    12
    Customer Support
    Tewksbury, MA
    just took a picture of both struts. both were taken from a level angle and both are the same distance and everything. the driver side strut looks to be leaning a lot more than the passenger side does. i'm not going to get a chance to actually take it apart until saturday unfortunately so i was seeing what options i have and any ideas as of this point to check or try to do on saturday. if i can't fix it then, i'm scrapping the whole thing and getting new suspension!
  5. Metalman
    7,700
    When you jack up the MINI with the tires off the ground, have you tried grabbing the wheel and tried shaking it real hard to see if something is loose?
  6. panaphobic
    Jul 19, 2010
    192
    12
    Customer Support
    Tewksbury, MA
    not yet. i barely have time to even take the pics. i've been doing it when i have a free couple seconds. i have 2 jobs i work so there's not much down time for me. i have saturday off so that's the only time i can get the chance to do something about it. i'm just trying to get any and all ideas about it right now so i can cover everything when i start working on it on saturday
  7. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Your strut isn't bent...
    so if the caster is wayy off that's not the part that is the problem. You bolt in new stuff and it will be that way too. Looking at your allignement specs, front right caster is 4.2, front left is 4.0. That's not very different.
    You want to get a new front suspension, have at it. If I were you I'd work to understand what's up with this now before spending more. How will you know what you're fixing?
    If there is a thunk, and something is that loose or hitting stuff, it won't be hard to find. You just have to make the time to find it. Start with:
    Looking for wear spots on the drainage channel and the spring. This is common and correctable. It also means that if you do go forward with something else that has beehive springs (and they use them for a reason) you may end up with the same problem, especially if you get something that lowers the car. -2 front camber isn't that agressive, but there are some that report interference with the spring at this amount of camber.
    If you do go aftermarket, the IE plates are good, and not all strut systems come with integral camber plates. So I wouldn't be so hasty as to move them on yet.
    Anyway, there is tons of discussion about what might be the issue. Instead of taking all the time typing, jack the sucker up and look for the problem!
    Matt
  8. panaphobic
    Jul 19, 2010
    192
    12
    Customer Support
    Tewksbury, MA
    if only i could do it now, i would. i just don't have the time to do it right now unfortunately. the suspension is something i'll end up getting no matter what, but if that is the problem, then i'll replace it. and i'm with you on figuring out what exactly is wrong. i need to fix that first before anything else. i'm just really trying to get every single option out on the board because lets face it. no matter how much you know, you can't always think of everything. and i'm not saying i know a lot either. i just want to have every angle covered and have every bit of knowledge about what could be wrong so i can find the solution fast on saturday.
  9. Metalman
    7,700
    Most important, don't fly off the freeway and get yourself or someone else "KILT".:eek6:
    Your MINI drove fine until you installed the IE plates. It has to be something that you did incorrectly. Those camber plates should not have caused this problem. I also don't buy the saggy suspension. Buying another suspension seems like the wrong move at this time.
    My advice to you is to take a day away from your girl & your friends. Take it to the shop & get it fixed right.
    My .02
  11. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    :Thumbsup: maybe a little more direct than I would say it but Crashton's on it
    We can speculate all we want and you appear to be beyond your mechanical ability (man I know that one)
    If your considering doing a whole new suspension money is not the issue, take it to the guys who do this for a living, maybe take a shot to the ego (once again, been there) and move on. Ultimately will save you time which seems in short supply with two jobs
  12. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    Crashton has a good point here. you didn't know your upper mount was broken until you visibly saw it one day while under the hood. Your car drove fine until you started playing with it.... unless of course you didn't text me bitching about that for some reason :beer
  13. panaphobic
    Jul 19, 2010
    192
    12
    Customer Support
    Tewksbury, MA
    lol Jeff man, that's why you need to move back! I need another MINI owner here! Jon’s useless for helping out and I’m always working when Shane’s not (shitty that we work at the same place for the same department, but different shifts lol) so I never have anyone who would actually help work on my car. My girlfriend has helped me out more than anyone when working on cars lol. She’s even helped me rip the engine out of my CRX the one day! She’s actually willing to help me out! She’s 1 in a 1,000,000! As for it being out of my mechanical ability, you're probably right, but I want to learn how to do this stuff. I have an understanding of it from other cars, but this ain't no Honda lol. I have a decent amount of knowledge, just not with a MINI. And I love working on cars. I fortunately won't be having to work 2 jobs for much longer. Just went officially full-time at 1 job so the 2nd job will be gone soon enough. Money is not that big of an issue but I’m also not going to be spending ridiculous money on stuff, lol. I’m not like "Nitromini" (no offense intended, your MINI is SICK!) and can't just try new stuff out all the time. I also don't want a "driveway MINI" (again, no offense intended). I want to learn everything I can about them, and I, along with most (speculating) of you guys, learn from experience. I really appreciate everything that you guys have been throwing out there. I appreciate every bit of information I’m given, and I take everything into consideration. When I get the chance to take it apart tomorrow, I’m going to be making sure to do everything right this time (I have the whole day this time, not just 1 hour) and I’m also going to be checking everything that you guys have been telling me to check. I’m just not use to the MINI's mechanics yet. If it was a Honda, I could rip that thing apart and put it back together! But this isn't a Honda, so I need to re-learn everything over again lol!
    As I progress more and more with the MINI, I’ll be deciding what to do as far as upgrading it. I still do want to get into racing it. But that probably won't happen until next year unfortunately.
    Again, I just want to thank EVERYONE for you're input here. Information is valuable and opinions are greatly appreciated. I take everything into consideration, regardless of what you guys say (being good, or bad, or telling me to go f*** myself lol). I hope to have my camera with me tomorrow so I’ll be definitely taking lots of pics. Maybe even video tape it if my video camera is charged.
  14. Metalman
    7,700
    Good luck with tomorrow.:D
    Sounds like your girlfriend is very capable, I'd be thinking about nursing a cold beer :beer and let her handle the struts. :Thumbsup::lol::lol::lol:
  15. panaphobic
    Jul 19, 2010
    192
    12
    Customer Support
    Tewksbury, MA
    LMFAO! That would be pretty nice! But unfortunately she doesn't know a whole lot, but she doesn't mind helping out at all. So I have to walk her through everything but she definitely is learning along the way!
  16. ZippyNH
    Another former CRX owner!! :D
    Fun car......especially if you put a JDM motor in it...I had a 89' HF that I put the JDM I motor in...I still wonder how crazy it would have been with a V-TEC!! Sold it a few weeks after buying the MINI in 2005, still kinda miss it!! Parked next to each other, the MINI looked HUGE!!! It just towered over it!!
  17. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    So it's Sunday....
    what turned up yesterday?
    Matt
  18. panaphobic
    Jul 19, 2010
    192
    12
    Customer Support
    Tewksbury, MA
    #38 panaphobic, Aug 1, 2010
    So yesterday I jacked the front end up and put it on stands. Took the wheels off and checked everything out. Everything seems tight and then I took a look at the springs to make sure they were seated properly. Found that the driver side upper plate was about a 1/2 turn off. So it was basically no where near where it was suppose to be. Here’s what it looked like. You can see the plate knuckle where the spring end is suppose to sit, and the spring end itself is basically on the other side.
    So I decide "well let me do it the right way and drop the suspension...." :idea:
    The bolt for the wheel carrier (or steering knuckle) broke off :mad5: where it bolts to the strut, even after I sprayed the s*** out of it with BP Blaster (mechanics best friend) and letting it sit for a while and I kept spraying it to ensure the bolt would be saturated. New England sucks for under body parts! The salt and other grime really does a number on your nuts and bolts! And I figure it probably has never been removed before!
    I did manage to do what I did last time and just drop the strut down and I spun the plate to the proper place and fix that, but I couldn't get the flatten the rib inside the wheel well and now it's definitely rubbing! :mad2:
    So here's the question. Should I take the whole assembly out and re-drill it, or do you think it would be wise to replace the whole thing (~$100 from ddmtuning.com | part # 31216757497). I still would need to drill out the old carrier to remove the strut either way, but is it going to be a huge pain in my a** to drill it out and still be able to use it? I do have a 114k miles on the car as is. What do you guys think I should do? What would you do if this happened to you?
  19. panaphobic
    Jul 19, 2010
    192
    12
    Customer Support
    Tewksbury, MA
    So I figure that since I'll be having to take the wheel carrier off to try and get the bolt out and replace it, (or just replace the wheel carrier itself, which sounds like a better and easier plan), I might as well replace the bearings and bushings since I'll have access to them at this point. I want to start auto-xing next year and this would be a good idea to replace them now.
    So this is the plan so far (unless a better option is available)........
    I'll replace the wheel carriers (steering knuckles) along with replacing the wheel bearings, control arm bushings, and sway bar bushings and pick up some suspension. As for what suspension I'll be going with, I'm not too sure yet. I'm gonna do some research on it and figure it out. But so far this is what it looks like I'll be getting right now:
    Column 1 Column 2 Column 3
    Part OEM Part # Cost
    Wheel Carrier (Left) 31216757497 $100.23
    Wheel Carrier (Right) 31216757498 $100.23
    Wheel Hub with Bearing (x2) 31226756889 $146.23
    Powerflex Front Lower Control Arm Bushings $79.95
    Powerflex Front Sway Bar Bushings $44.99
    Total without Suspension $617.86
    If anyone thinks I should replace something else that I didn't list, let me know. I figure I might as well replace now what I'll probably need to replace soon. No more surprises then. The winter abuses the hell out of my MINI so I think it'd be wise to replace this stuff before it becomes a problem. High mileage and bad winters don't mix well as you can see. I have the money to spend, so I think the preventative maintenance now will save me later.
  20. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    Just a silly question, but wouldn't it be easier to just drill the screw out and replace it? Heck of a lot cheaper, fo sho.
    Sorry about the issue. Steel doesn't seem to be what it used to be... :cryin:
