Suspension Brakes Installing springs
Discussion in 'Tuning and Performance' started by leicaguy, Aug 23, 2010.
  1. BThayer23
    :Thumbsup: What Keith said. :D
    Way Motor Works sells the TSW R56 springs. I haven't driven those on the R56, but I can vouch for them on the R53.
  2. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    take the strut assembly out of the car. its just that one more giant bolt clamping the bottom, and the sway bar link, which is cake to remove.
    You wont regret it.
    If you are not using an impact to force it all together you could easily have a second person just push on the top mount and compress everything that way.... the lowering springs only compress a very little bit. Didnt need compressors when i did the H&Rs
  3. leicaguy
    leicaguy New Member
    Aug 22, 2010
    Medical Tech
    Catawba (near Roanoke), VA
    I have an impact gun.
    I've just about decided on these:
    TSW MINI Performance Springs R56 - R55 - R57 - Way Motor Works
    and
    Ireland Adjustable Camber Plates R55/R56 - Way Motor Works
    or
    Ireland Engineering Camber plates (non-adjustable) R55/R56/R57 - Way Motor Works
    Comments?
  4. iwashmycar
    Jun 1, 2009
    881
    87
    architecture
    i dont think you need adjustable unless your autoXing or the like. I didnt read the rest of the thread, but you can get proper alignment w/o plates
    and with the impact, youll be just fine... put a towel over the stock spring, step on it, and let er rip... doesnt shoot very far at all.
    when you put the new ones in and have it all ready to reassemble it helps to have another set of hands to push down like i said earlier (just to get to the threads) and then impact the new top nut on.
    AND, sorry if i missed it... any desire for new struts?...seems like you get a lot of bang for your buck as the stockers are trash.... youll be lucky to get more than 30K out of them
  5. btwdriver
    btwdriver New Member
    I would stay away from the IE adjustable camber plates. From what I have heard they are junk. The fixed plates are the way to go if you are trying to save some money. Otherwise save you pennies and get the Vorshlag adjustable ones.
  6. BThayer23
    #26 BThayer23, Aug 24, 2010
    The IE adjustable plates use a bushing that is prone to wear out early and they raise the ride height (although later revisions may have fixed that). If the intent is to save money, get IE fixed plates, but if you're going to step it up, hold out for the Vorschlag plates. I have them on my R53 and they're awesome. No compromises, an excellent product, and worth the extra expense.
    Ask minimark, he ran the fixed plates for a while before switching to the Vorschlag plates (developed by TSW, btw). He said there was definitely a difference between the two - the Vorschlag plates are stiffer and harsher, but steering is point and shoot. The fixed plates are a great way to get the car to neutral while keeping a street feel. And if you have the shocks and springs apart already, given they're half the price of the Vorschlag plates, they're a smart option.
  7. leicaguy
    leicaguy New Member
    Aug 22, 2010
    Medical Tech
    So Ben, what camber do you have the plates set at? Do you change camber from street to track and back again? Or do leave it the same for both?
  8. minimark
    Definately no comparison on the track between the fixed IEs and Vorshlag. That said the IEs are heads above the OEM and will get you around the track much faster. Paid 180.00 for the IEs and drove them for 20,000 miles then sold them for half the price when I upgraded, pretty hard to beat the value per mile when your on a budget and doing other things to the car too.
  9. BThayer23
    I have mine set at -2.0 degrees of camber. That's the most I can get with stock springs. I'm not sure what the limit is for the R56, but it's probably close to that. Fixed plates would definitely put you in the right ballpark, somewhere between -1.5 and -2.0. Adjustable camber plates really means "fine-tuneable." You have to set the camber first, then set the toe. Adjusting one will alter the other, and not in the good direction.
    As far as specific alignment settings go, there's a few different opinions out there. A good place to start with a 19mm rear sway bar and springs is -2.0 front camber, -1.5 rear camber, zero front toe, and a little bit of rear toe in. I have a serviceable knowledge of suspension settings, but there's a bunch of information elsewhere on the boards and on the web about how certain changes will affect the car.
    This is my favorite alignment post (on the sewing site):
    North American Motoring - View Single Post - what are your alignment settings?
  10. leicaguy
    leicaguy New Member
    Aug 22, 2010
    Medical Tech
    OK, lets back up a step to my original plan, that is to install lowering springs only. Will that alone allow for any more neg camber? Or do definitely need camber plates to get beyond factory camber setting?
  11. minimark
    You will need camber plates if you want more negative camber. Springs alone will not change the camber, as the strut will still be located in the same position.
  12. iwashmycar
    Jun 1, 2009
    881
    87
    architecture
    true.. technically it will be a very slight bit more camber, since when you lower the car, the bottom just 'swings' outward but the top stays put.
    the rears tend to get a bit more, but they still have some adjustability if im not mistaken.
    If you have specific settings in mind your going to want the adjustability
  13. BThayer23
    #33 BThayer23, Aug 25, 2010
    The way the geometry works when you lower the car, the front gains a little bit of camber, less than 0.5*, and the rear picks up another degree or so, -1.0*. However, adding rear camber makes the car understeer even more and defeats the purpose of making the car drive better.
    In a perfect world the front would gain more camber when you dropped it and toe out would increase with more negative camber. But unfortunately the suspension relationships are not conducive to cheap upgrades.
  14. btwdriver
    Someone is selling a set of the Vorshlag camber plates on the sewing site right now. You might check those out.
  15. Doggybags
    Doggybags New Member
    When I purchased the fixed IE plates from Way he very specifically recommended NOT to use lowering springs with them. You might want to give Way a call just to see what he recommends for you.
  16. leicaguy
    leicaguy New Member
    Aug 22, 2010
    Medical Tech
    Sewing site?
  17. btwdriver
    LOL... sorry NAM.
  18. minimark
    Lol OK I stand corrected you would get a very small amount of negative camber in the front but depending on the drop and the type of plates (IE) it would be so small that it would be almost insignificant. The rear geometry on a Mini seems affected more when lowering than the front as I think Ben was eluding too. He also made a good point about the effect of camber on one end of the car to the other. If you increase negative camber on the rear say by -1 degree it will negate some of benefits of the same -1 degree increase on the front. To decrease under steer you want to increase negative camber on the front while decreasing it on the rear. How much depends on the the car, the driver and the track that he is running on. 2cents
  19. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    The importand change
    isn't the change in camber when at rest, but when compressed in a turn. lowering springs on the front will change the rest camber a little bit, but it doesn't alter the fundimental geometery of the car, and when compressed in a turn the numbers won't be any different. To change this you need to do something to the geometry.
    Another thing that is being missed here is that no matter what springs are run, the front wheels are too verticle for good contact patch management for the front wheels. This means that cornering limits are lower and tire wear in turns will be worse.
    Springs are an easy mod, the OP can slap a set on and see if all is good. Adding the camber plates later is pretty easy ( 6 bolts a side plus the lug nuts).
    But if it were me, I'd do the plates first before springs.....
    Have fun with it whatever way you go!
    Matt
  20. leicaguy
    leicaguy New Member
    Aug 22, 2010
    Medical Tech
    #40 leicaguy, Aug 25, 2010
    I still want to do both I just can't seem to come up with a plate spring combo that doesn't present a problem of one sort or another (according to various posters). Right now I'm leaning toward:
    NM Engineering or TSW Lowering Springs
    and
    Vorshlag Camber Plates
    Any contradiction in using these together?
