1st Gen R53 Cooper S Intermittent Red Oil Light
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by mistertripps, May 2, 2013.
  1. 00Mini
    Nice post. Welcome to Motoring Alliance !!
    • Like Like x 1
    • Agree Agree x 1
  2. ERR404DRG
    ERR404DRG New Member
    Apr 20, 2020
    6
    11
    Thanks for the positive feedback, honestly I was just a little lost and wanted to make this easier for others running into the same problem. I think it'd be great to make the post an article so others can find it easier!
    PS: Car is a 2003 Cooper Base and I'm located in Houston, TX
  3. Chkita06MCS
    Chkita06MCS New Member
    May 5, 2020
    Female
    Hi all -- I'm new here and very lost as I've been having the low oil pressure problem for quite some time. I'm now having the oil pump replaced as nothing else has worked. If this doesn't solve the problem, the mechanic says it's likely the engine is damaged -- but he's checked it for signs/symptoms of damage and has found none. I'm praying the pump replacement finally fixes the problem because I really don't want to part with my mini. Bought her brand new and have never wanted any other car since. Still don't. Any words of wisdom or advice would be most appreciated
    Thanks for being here to help.
  4. ERR404DRG
    Apr 20, 2020
    6
    11
    My issue was very similar, and it was the filter missing the inner structure causing pressure irregularities. Before dropping money on an oil pump I'd highly recommend looking at the images I posted previously to see if you have the older style oil filter housing like I had and see if it has the correct Oil filter, Spring, and Cage like the image below. I replaced the entire housing in the troubleshooting process and now have the later model which doesn't have the cage. If that is a route you would like to take you can order a new one from ECS Tuning ( https://www.ecstuning.com/b-genuine-mini-parts/oil-filter-housing/11427563522/ )
  5. Chkita06MCS
    May 5, 2020
    Female
    Thank you so much -- I will share your photos with the mechanic so he can verify that first.
  6. ERR404DRG
    Apr 20, 2020
    6
    11
    Also, if you do have the later model I read that sometimes the plunger and or spring in the actual housing can break causing a similar issue. I circled the spring and plunger below, if they are damaged and/or missing you can replace the housing with the part linked above.
  7. wmwny
    4,040
    2,242
    Welcome to BOTH of you into M/A! Your problems and hopeful solutions are what M/A is all about. We are here to help out with suggestions and possible fixes whenever possible.
  8. MCS02
    Welcome to MA!
    • Like Like x 1
    • Agree Agree x 1
