1st Gen R53 Cooper S Is it normal to hear your shift linkage when shifting
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Kooperscooper, Mar 24, 2012.
  1. Kooperscooper
    Kooperscooper New Member
    Feb 8, 2012
    Hey Folks.
    I am one of those conflicted new mini owners who didn't realize what he was getting into until it was too late. :eek6: But I digress.
    I have an 03 Cooper S with a 6 Speed manual. When I shift I often hear all the linkage clicking around as I move the shifter between gears. Kind of like on the Fast and the Furious movie when those guys are racing each other and it seems like the microphone must have been shoved down near the shifter. Is this normal? Does something need lubrication?
    Also, sometimes when I depress the clutch peddle it feels rough like something is rubbing against something that is not smooth. But only sometimes. It feels and sounds like its coming from where the peddle pivots above my foot, under the dash, not like its actually in the tranny. Please tell me its not the actual clutch:confused5:
    Any help would be appreciated.
  2. 1972Austin
    1972Austin New Member
    Mar 20, 2011
    33
    Yorktown, Va
    As far as the linkage being loud, that's the nature of an R53. They are clunky and loud and personally I love it. The clutch pedal on the other hand I'm not sure about. Try throwing some grease on the linkages and see if that helps.
    Shawn
  3. Austinsynthetics
    109
    44
    California
    If you are stopped and the clutch is out, is there is a noise almost like a noisy rotation? And if so, does the noise go away when the clutch is depressed? If so, could be the throwout bearing.
  4. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    Also with the throwout bearing. If your pedal is relatively quiet when the car is still warming up. But then gets the rubber on rubber kind of grind/groan when warm. That is also a sign of a bad throwout bearing.
  5. DixonL2
    DixonL2 New Member
    274
    A bit north of the 'burgh, PA
    Some linkage noise, esp on the 1-2 shift you'll hear a clack, that's normal.
    The good news: Feeling like you're pushing a screwdriver through a bucket of rocks when you depress the clutch is not the clutch (phew for that!). The bad news is it's highly likely the throwout bushing or sleeve (not bearing) going away. It's something like a $10 part but you've got to "break the seal" between the engine and trans to get at it, which means the front of the car comes off, so may's well do the clutch while you're in there. Good news is it'll run like that for a long time (mine went 10,000+ miles with a slight gruntch on clutch depression before I decided to replace it). How many miles on the car? Gotta say the new clutch is a JOY. Mine went South about 65k (the bushing, not the clutch), and I've had Mini friends who've experienced the same thing about the same mileage. Sorry...
  6. Kooperscooper
    Feb 8, 2012
    Thanks for the info folks. I got the same feedback on another sight as well. I dont think its too bad yet so I may let it ride for a while. It seems to me that buying an R53 in the 70 to 80K milage range is the wrong time to buy (as I did) I should have looked for one with 120K on it. Then all the design flaw maintenance items would have already been taken care of.
  7. DixonL2
    DixonL2 New Member
    274
    Nyaah, 70k is fine. All cars have their issues around 70k, and likely again around 130k, parts simply have a finite lifespan. Good news is parts aren't hard to find, and despite the tight confines of the engine compartment, it's not all that hard to work on it once you've got the hang of Service Level 1. OK, ok, it's difficult, but not impossible.
  8. yellowbritishrocket
    May 16, 2009
    618
    277
    i have a 03 and went 137k miles on the original clutch setup...
    the cables will make a clunk or another random noise...remember these are cables that are inside plastic guide tubes...also if the rubber inside the linkage ends wears down the more the clunk will appear...to replace them is not a difficult task...just alot of parts to move out of the way
    now as for the clutch pedal...it sounds like the throwout arm bushings are going bad or have gone...they are while nylon end caps on the throwout arm...and there is no way to fix them from the outside so the trans will have to be opened to replace...and while your in there to make it worth your while...replace the clutch too
  9. DixonL2
    DixonL2 New Member
    274
    ^^ what he said ^^
