Engine Drivetrain 2nd Gen S Is it worth it to go E85?
Discussion in 'Tuning and Performance' started by ChItalian1027, May 2, 2017.
  1. ChItalian1027
    ChItalian1027 Member
    Sep 17, 2012
    103
    19
    IT
    Westfield, IN
    Ok guys, so my question is, is it worth it for a stock R56 to get a tune for E85 and run it or should I just stick to using 93?
  2. JPMM
    JPMM Member
    Feb 12, 2016
    101
    I don't think you can do it. The car and its computer /fuel supply will not support it without major $$$$.
  3. Firebro17
    From what I remember, E85 and the MINI engine doesn't play well together. Someone else may have a better idea and more info.
  4. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Don't do it. Run 93 and be happy that your MINI is happy :)
  5. Zapski
    You'd need a new or flashed ECU, new injectors, new pretty much everything fuel system related....
    I wouldn't.
    Now on the other hand, if I had a mid-90's Subaru that I didn't care much about and for which there are plenary of after market ECUs, injectors, and so on that are specifically made for that kind of thing, then.... I probably still wouldn't bother. I say this because when I had a mid-90's Subaru, I thought about doing this and then didn't bother. ;)
  6. ChItalian1027
    Sep 17, 2012
    103
    19
    IT
    Westfield, IN
    Thanks guys, I will be sticking with 93.
  7. cct1
    I made the switch. For a track car, it's worth it. For anything else, probably not. As has been noted, you'll need a new fuel pump, rail, injectors, ECU, etc. It's not cheap.
