2nd Gen R56 Cooper S Is this noise normal? I need your opinion.
Discussion in '2nd Generation: 2007+ R55 through R61' started by TheEggO, Jan 5, 2013.
  1. TheEggO
    TheEggO New Member
    May 1, 2012
    11
    Hi guys,
    I got my 2010 JCW pre-own with 20k miles. Since I got it, it has this knocking sound that bothers me. Took it to the dealership complaining about a weird engine noise, they checked it and found nothing wrong. I felt that I was not very specific when describing this noise to them, and thats probably why they ignored it.
    After researching in the forum, I became aware of the common problem with the timing chain, I took the car back one more time a week later, and this time being very clear that I wanted them to check the timing chain tensioner.
    When I got the car back they told me to change the chain tensioner (part 11-31-4-609-482)
    Here is a clip of my car after they replaced the tensioner. The sound is still there.
    [ame=http://youtu.be/8BOfCmUKZ8M]Mini Cooper timing chain noise - YouTube[/ame]
    So I'm wondering is this is a normal sound for the car. Or is something still wrong.
    What do you think?
    Thanks
  2. Joe
    Joe New Member
    Jan 6, 2013
    It seams a bit loud but normal IMO.
  3. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    I vote normal. I do not hear any timing noise... just valve noise.
    Maybe Seafoam it or worst case it needs some of that carbon buildup cleaned out.
  4. Mr. Jim
    I'd say normal also, that's the thing with that engine which I'm noticing with our 13 CM, a hell of a lot noisier than the R53 engine.
    I find the engine in our R55 justa to be nosier than my R53. That being said it is much quieter than the OP's DI Turbo Prince of an engine.
  6. Metalman
    Suggest you might be hearing some ticking from the high pressure injectors used with the DI engine.... Which is normal.... My fuel rail pressure at idle is around 750psi and I am used to hearing the ticking sound of the injectors operating....
  7. Jason Montague
    :cornut: It sounds like Margi(08 BRG R56 MCS/JCWm) after her oiler and timing chain were replaced. To me she sounds like an older Singer Sewing Machine.:Thumbsup:
  8. TheEggO
    TheEggO New Member
    May 1, 2012
    11
    Thanks for the feedback guys.
    This morning I started the car again and I feel the sound is different when I do a cold start.
    It's driving me crazy. Please, I need more feedback. Is this normal?
    [ame=http://youtu.be/xccgkarLWBs]Mini cooper cold start noise - YouTube[/ame]
  9. Metalman
    This time I heard a ramdom clanking sound....
    Check your oil level (the dipstick can be difficult to accurately read....)
    If your oil level is low, you may not have adequate oil pressure to set the chain tensioner, which will then leave too much play in the chain...
  10. TheEggO
    TheEggO New Member
    May 1, 2012
    11
    The oil level is high. The mini technicians always add to much oil. I hate it. :mad:
    So, should I take the mini back for service? What should I say this time?
  11. iwashmycar
    Jun 1, 2009
    881
    87
    architecture
    THAT sounds a little like the tensioner noise to me. Has that clacking sound amongst the usual valve clicking sounds.
    Does it sound bad outside the car when you give it throttle?
    This is timing tensioner noise from outside the car. If it still revs and sounds normal, then I would venture to say it is. They are just very annoyingly loud engines.
    http://s13.beta.photobucket.com/user/iwashmycar/media/Mini/Outsidecar.mp4.html
  12. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    In the 2nd vid, you can clearly hear the clunky bag-of-hammers sound. This too is normal.:)
    That did not go away when my tensioner was changed either and my engine always ran strong.
  13. OhBe1
    OhBe1 New Member
    Aug 10, 2012
    16
    First one sounded like mine. The second... I'd call it clacking rather than clanking, but I'd bring it in.
    My dealer overfilled mine, too. I had them drain it.
    Oddly, mpg went down 2 after that...
  14. countryboyshane
    countryboyshane New Member
    Jul 23, 2009
    202
    Diesel Engineering
    Bloomfield Hills, MI
    His doesn't sound that bad. My car sounds similar the first five minutes when it starts up but after that it smooths out. It doesn't sound offensive...yet
