Isobell, The RatRod Project
Discussion in 'Car Builds, Projects, Idea's Experiments' started by TheModFather, May 10, 2014.
  1. TheModFather
    I dont really drink anymore... Think I might of had a 6'er since the new year! :)
    2015 is going to be a good one for me I hope... No more smoking, no more binge drinking, and I finally get to drive my R53 again!
  2. TheModFather
    Got to make sure to get it all in! :D
  3. RallyMini370
    hahahahahahahh I love that photo! I cut back on the drinking too! I don't start now until after mid day. when I'm woking I have to wait until at least 6pm but it's 5 o'clock somewhere by then
  4. DneprDave
    Good for you! I don't have time to make my own, so I buy my smoke, when working on the electrical system.
  5. TheModFather
    I've seen that pic before... Thats where I got the idea!
    :D
  6. wmwny
    4,040
    2,242
    Just be sure to give up your "Smoking on the Dragon" AFTER April 29! :ihih:
  7. TheModFather
  8. DneprDave
    That'll lighten the car considerably.
  9. Dave.0
    YAY Now the real FUN begins.
  10. TheModFather
    It should go back together easy... As long as I can find all my nuts. (Unfortunately that is a common problem:() then its just hoping everything else still works!
    I should be taking the Porker up to Grand Junction soon to get the ViPEC so I can actually start and drive it! :)
  11. cct1
    Wow, great pic. My car gets sent to Jan tomorrow. That picture just made me feel a helluva lot better not doing what I'm having done here....
  12. TheModFather
    It's really not that bad, minus having axle shafts seised into the hubs, the starter is a TOTAL PITA to remove and the shift cables can be a little tricky...
    Only took 5 hours with minimal use of air tools, even with the 1/2 hour spent trying to knock the Driver Side axle out.
    Too bad it's not like my old Samurai... 1 1/2 hours to remove the complete drivetrain minus the axles! Most of that was spent letting the engine cool down first. ;)
  13. TheModFather
    Looks like the total damage was minimal... No scaring on the crank or rod from the spun bearing! Probably could have got away with stuffing in a new rod bearing set from MINI ($350.00 fix), but it also looks like I was about to pop the head gasket on #2...
    Now its off to the tool store for the right socket to get the clutch off. :(
  14. TheModFather
    Anybody know where this goes?
    Not sure, but it tastes great! :)
  15. DneprDave
  16. Spa2k
    Spa2k Well-Known Member
    May 9, 2013
    1,955
    975
    Iowa
    Isn't that a paperweight? I've seen ones like it in the offices of several shops around here.
  17. TheModFather
    I've got plans for it... ;)
  18. TheModFather
    Well if the weather holds out, there will be a working engine in the Rat-MINI by the end of the week! Then its an 800 mile round trip drive one day to pick up the ViPEC before I can see if everything is going to work. :(
    Thats not the end of the project though... Still lots to do! I need all the clips that hold the trim on, still have a few things to paint if there is time, and still have to go through everything to make sure it still works. All of that has to get done before I leave for the Dragon on April 24th, wish me luck, I'm gonna need it!
  19. cct1
    Get it running. The rest of that stuff is gravy.
  20. TheModFather
    Done for the day...
