Isobell, The RatRod Project
Discussion in 'Car Builds, Projects, Idea's Experiments' started by TheModFather, May 10, 2014.
  1. c0op3r
    c0op3r Active Member
    Oct 2, 2013
    196
    133
    Mech Eng and IT
    Orlando FL
    Motor side of the harness?
    Let me go see what I can find, the ones I have had in the past I have sold for about 100$ so they are not that bad.
    The pain in the dick, is the interior harness, it weighs about 45#'s and is a monster.
    Sorry can not help with the seized bolt, PB Blaster I guess. I had to do my wheel bearings, and I busted two pullers getting it off, and a lot of PB Blaster but I got it, and it was not even the BAD ONE! Doh! well at least they are both changed now.
  2. c0op3r
    Oct 2, 2013
    196
    133
    Mech Eng and IT
    Orlando FL
    What is this, trying to figure out which I have.
  3. TheModFather
    The header was the standard shorty, until I had to add a couple wideband O2 sensors...
    So the guts got knocked out of the cat (with a BFH) and the additional O2 bungs got welded to the shell of the "cat". ;)
  4. TheModFather
    ViPEC is on its way to Colorado!
    Now to set up a day when I can drive to the other side of the state and pick it up. :)
  5. MCS02
    Take a day off from work. You need to get your prioritys straight!:D
  6. TheModFather
    If need be, I will! The roughneck I'm buying it from is NEVER home!
  7. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    I bet you can repair the harness. Just spend a couple of hours with a wire stripper a good soldering iron and some shrink wrap. It'll be cheaper than replacing the whole thing.
  8. cct1
    I bet he can't....:devil:
  9. TheModFather
    All these years, and all that BS when I was screwing around with the POS's at Mynes, has taught me to do it right or not at all. ;)
  10. TheModFather
    Hmmm...
    Wonder what that is?
  11. cct1
    Whatever it is, it needs a dent.
  12. TexasChiliS
    TexasChiliS Well-Known Member
    73
    And rust - although appears stainless
  13. DneprDave
    It's a wall sconce
  14. TheModFather
    Its aluminum... ;)
    Needs mor cowbell! :D
  15. minirab
    That's a Sharpie on the left, the rest I don't know!:idea:
  16. cct1
    Dick chews. It's a spittoon that will replace a cup holder. Or maybe it's the first MINI bidet for little people.
  17. TheModFather
    Nope, it's time to build the front panel of my intake.
    Killed my drill batteries, so it's break time until one is charged. :(
    More to come in a little bit. :)
  18. Spa2k
    Spa2k Well-Known Member
    May 9, 2013
    1,955
    975
    Iowa
    Oh - that's disappointing. Before you started messing with it, I thought it was the canopy mount that goes over the electrical box to mount the chandelier to the roof of the car. Too bad - it would have been a nice touch of class for the interior. :yesnod:
  19. TheModFather
    I dont even have a dome light!
    But this, this is looking GOOD!!!
    :) :) :) :D :D :D
  20. cct1
    Needs more rivets.
