Brakes Wheels 1st Gen Tires JCW BBK Caliper paint death
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by mini_racer, Sep 19, 2009.
  1. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    So, I have an ’06 JCW car, which means among other things it comes with the JCW BBK. I only have about 20K miles on the car and after every DE, of which there has only been a few, the paint on the calipers gets a little more scorched. No, it is not dirt or brake dust, the paint is actually turning darker. I realize brakes get pretty damn hot, but still. Should this be expected? I thought the JCW BBK was designed for heavy usage.
    Note that the carriers still look great, but then again they do not actually touch the pads, or at least just barley touch the tabs on the ends of the backing plates.
    Those were XP10 pads I had in there from a recent DE, and my original rotors. And on the pads, they came as a bright red, almost orange color out of the box. Well, uh, that color did not last very long and was almost gone after the first session.
    I have not experienced significant fade, or ever boiled the fluid. So, I did not expect to cook the paint.
    Anyone else kill the paint on their pretty JCW BBK calipers?
    It looked like this a year ago, I also had some fresh paint on the rotor hat.
    Today, it looks not so nice with the much darkened paint.
  2. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
    normal. the red Brembo's on EVO's turn maroon with heat cycling at the track
  3. mini_racer
    Engr Manager
    Yeah, I guess so. Maybe brake ducts would help a little bit, but it would probably just turn dark anyway, just a little more slowly.
    Well, that's a tell tale sign of who has been going to the track.
  4. PGT
    PGT Wheel Whore
    Leesburg VA
    yep. the gold ones on Nissans and Subaru's turn a dark gold instead of bright gold. I'm trying to find pics to show you but googling isn't helping much
  5. BlimeyCabrio
    I repaint my calipers frequently... for this very reason. It's not just a mod... it's a lifestyle.
  6. PGT
    PGT Wheel Whore
    Leesburg VA
    could just do this....
  7. goaljnky
    3,105
    394
    Mine look the same. Just shows that they get used hard.
  8. BlimeyCabrio
    Heh :cornut:
  9. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Here's an idea....
    Strip them and put on one of the baked on heat transfer thermal coatings.... They wouldn't be as pretty, but you would probably shed some more heat.
    Painted calipers look nice, but that's about it.
    Matt
  10. mini_racer
    Engr Manager
    Maybe I should just wear my burnt paint as a badge of honor. After all, I did earn it!:lol:
    Yes!! Consider it a feature.
    JCW Brakes with unique heat treated custom Red/Black finish.
  12. Alan
    Alan Active Member
    98
    New Braunfels, Texas
    +2
    Clean cars are slow!
    Alan
  13. Sideways
    Sideways New Member
    May 12, 2009
    539
    37
    Above the Border^^^
    Show or GO...
    It's up to you
  14. BlimeyCabrio
    Mine "goes" and "shows".
    Just takes a LOT more work to do both.
  15. mini_racer
    Engr Manager
    Yes, plenty of work indeed. I also do not believe you have to make an exclusive choice of the two, having it all is more fun. :D
  16. AMG-RX7
    AMG-RX7 New Member
    Oct 7, 2009
    36
    Mountain View, CA
  17. orangecrush
    orangecrush New Member
    May 13, 2009
    137
    I don't know how revelant this is but on my last 2 coopers both of them did track days (including VIR which is extremely hard on brakes....at least more so than Mid Ohio or Roebling) and so far the brakes stay red. (my '08 MCS had 20K on it and my JCW now has 13K)
    Point is, I always make sure my calipers are clean. I don't know if the dirtiness "bakes" into the calipers and makes them turn dark prematurely but so far, mine are as shiny red as they were when they were new.
    Of course, I wash my calipers (along with the car) at least 2-3 per week.
    Mark
  18. mini_racer
    Engr Manager
    I keep my car, including the brakes....very clean. The issue is not cleanliness or baked on dirt, etc. It is a simple heat issue which is slowly burning the caliper paint, scortching it and turning it darker and darker.
  19. orangecrush
    May 13, 2009
    137
    Oh well, there goes my reason for washing.... :D
    Mark
  20. mini_racer
    Engr Manager
    Ok, so I finally got around to refinishing the calipers such that they are nice and red again.
    I was able to tape around the JCW logo, and the color match was almost perfect. I used Duplicolor caliper paint. While the product claims a 500F tolerance, I sure wish it was more like 1100F. anyway, the plan is for the new brake ducts to make a difference and keep the temps low enough so as to not scorch the new paint. The next track day will tell, but for now, they look new again. :D
    [​IMG] [​IMG] [​IMG]
    The driver's side was worse, and I would guess is it is because most of my track time has been clockwise. Anyway, here is a before pic, and see that the scorching extends much further on the caliper. The after looks like the passenger side. This first pic is dirty, but you can tell that the carriers still look fine, no scorching.
    [​IMG] [​IMG]
