Brakes Wheels 1st Gen Tires JCW Sport Brakes ~ Best Bang for the Buck
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by GrAy RaVeN, Jul 2, 2009.
  1. GrAy RaVeN
    GrAy RaVeN New Member
    Kits from Dealer are running around 700 dollars !, includes upgraded rear brake pads too !
    My S's OEM brakes and calipers / rotors had some 75,000 miles on them. And I was looking at new orig equipment. Instead - Inskip Mini in RI set me up with the JCW Sport Brake kit for about the same price as the original stuff..... Front disk is 12.1 inches....Big difference in braking power and yet still OEM and unlike other kits - it comes with a warranty too :D
  2. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
    my local dealer wants $2k installed for them. :lol: I agree, best bang for the buck out there, if you DIY the install (not hard) and get a fair price for them.
  3. Batrugger
    Batrugger New Member
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    That was a good price for the JCW kit. I've also seen OEM R56 takeoffs go for as little as $200 and are essentially the same brakes. something for others to look at if they are considering this.
  4. PGT
    PGT Wheel Whore
    Leesburg VA
    yeah, but they're used and don't include the same pads, front or rear. $700 is cheap for a brand new kit. I think I paid $900 (going rate from Morristown).
  5. //MZero
    //MZero New Member
    Jun 21, 2009
    9
    Not bad, but my Wilwoods are 13"x.95, and a 4 piston caliper, and massively thick brake pads. That kit was ~$1200...yes 500 more, but it is more braking power, and less weight. The aluminum hats and floating rotors save a lot of weight, as do the calipers.
    For $700 I agree that the JCW kit is a pretty good deal, and enough braking for most. But I know there are others out there like me. Who, like me, kind find the limits of even the large kits.
  6. Aeromax
    Aeromax New Member
    Jul 24, 2009
    31
    Graphic designer
    Trumbull, CT
    Will JCW brakes fit under 15's? Normally I wouldn't care, but on a DD in the northeast, I need my winter rims. :D
  7. PGT
    PGT Wheel Whore
    Leesburg VA
    some, yes. I had 15x7ET42 Volk TE37's and ran JCW brakes
  8. goaljnky
    3,105
    394
    I run 15x7 Kosei on mine. Barely clears it, but it clears it. Just don't go off road and catch a rock between the rim and the caliper. Almost lost a wheel on the track doing that.
  9. BLUCOOPR
    BLUCOOPR New Member
    May 21, 2009
    79
    Retired Truck Driver
    Charlotte, North Carolina
    I have regular pads on my mini s and was thinking about upgrading. I changed the rear ones at 74K and have 87K miles on the front and they have never been changed on my 2005. Dealership tech said I was probably good for another 5K. Maybe I should just stick with the regular pads. Although I do not race or autocross this vehicle has been on VIR 2 times, Carolina Motorsports park race track once, top of Mt Evans 4 times, Pikes Peak 3 times, Mt Washington NH once. Dragon 9 times in the past 5 years. I think that I do drive agressive, but being a retired trucker, I do use engine to brake, ie downshift alot. Which drives my wife nuts cause I don't use the clutch most of the time.
  10. Nathan
    And I bet the clutch is in great shape as well, amazing the life one can obtain when being gentle on the equipment while still having fun. Maybe one day I'll learn how :D
  11. Aeromax
    Aeromax New Member
    Jul 24, 2009
    31
    Graphic designer
    Trumbull, CT
    I wonder if the jcw brakes could fit under holies. Those are the 15's i have, but I'm going to guess no.
  12. goaljnky
    3,105
    394
    You would be correct.
  13. mini_racer
    mini_racer Well-Known Member
    Engr Manager
    #13 mini_racer, Jul 31, 2009
    So, do the JCW slotted/drilled rotors have any significant performance benefit over the smooth faced rotors? Sure they look pretty cool, but do they make a difference for autoX or track events?
    Does anyone have any positive experiences with aftermarket rotor alternatives for the JCW BBK?
  14. mini_racer
    Engr Manager
    BUMP, Come on...... Someone has to know something!
  15. cct1
    No. Slotted/cross drilled rotors are bling, not only is it bling, it's potentially harmful bling. Drilled rotors are prone to cracking at high temps--probably won't make a difference at an autox, but on the track it's more of an issue.
    As for slotted rotors, the slots scrub the pads, and MAY improve gas dispersal, but that's debatable. I've run both slotted and smooth rotors, and I personally prefer the smooth faced rotors--I don't like the "feel" of the slots when threshold braking. You could certainly make an argument for slotted rotors, but I personally don't like them.
  16. mini_racer
    Engr Manager
    Consistent with some other reading, thanks.
  17. Nathan
    Slots make it easy to gauge wear at a glance when they are correctly machined to limit of rotor wear depth. I can't feel the difference between slotted and smooth rotors.
  18. BThayer23
    Slots help in the rain. Drilled rotors, when done well (see: Porsche), make the rotors lighter. The JCW rotors aren't big enough where that makes a significant difference, though. But I agree with the previous post - I've never seen a race car with drilled rotors.
  19. mini_racer
    Engr Manager
    Since we are talking First Gen JCW brakes, I will soon be looking for some track pads. I still have the OEM pads with plenty of meat.
    My street pads are Hawk ceramic, they are actually nice for the street given the low dust, but can make a noise or 2 every now and then.
    I have also used the Hawk ceramic on the track, and they were not the best. I actually think the OEM pads would be better for the track.
    Anyway, I am looking for some track pads, and options included:
    - Just get new front and run the OEM on the rear
    - Get new front and rear that are track oriented.
    I know brakes are somewhat subjective, so just please share what you are running on your JCW brakes for the track.
  20. cct1
    Brakes are subjective, but in general, it's not a place to compromise. There is no such thing as a dual duty street/track pad; it amazes me people will spend all sorts of money gettting more HP and ignore the most important thing the car does--stop. Not pointing fingers at you, I was in the same category, learned it the hard way not to compromise on brakes.
    So if you're going to the track, I'd put dedicated track pads on front and rear. You can leave the rear pads on for the entire season, then swap them out for street pads when you're track season is over--the rotors will hold up fine. Not so for the fronts; I would swap out for the track, then back to OEM when you're done. The JCW pads are not so hot for the track, ask me how I know...
    I would recommend carbotech's for the 1st gen JCW brakes, I think Dustin at Autoxcooper has them. You can also get carbotech's for the rears, but there are other cheaper options for the rears that'll work just fine (rear rotors are cheap). I'm not sure of any other track pads for the JCW's other than carbotech's, maybe someone else can chime in. The carbotech's are pricey, but they work great, and they're very rotor friendly.
