1st Gen 100K+ Just a little over 100K
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by xsmini, May 27, 2009.
  1. xsmini
    xsmini Member
    May 27, 2009
    46
    20
    Bishop, Ca
    Ha - wow, that was awhile ago. The $5.00 fix only lasted a couple of weeks, I ended up buying the replacement actuator here.
    On mine the cable had become dislodged from the regulator, so the whole regulator ended up needing to be replaced. I'm not sure why it happened, and haven't seen another one do the same thing. The window was stuck 1/2 way down because the cable had jammed up. The motor was still working.
    It is somewhat common for the motor to stop working, some say if you hit the inside of the door just below the handle it will make it work again. Others say the electrical connections need to be cleaned.
    Good luck,
    Nik
  2. xsmini
    xsmini Member
    May 27, 2009
    46
    20
    Bishop, Ca
  3. Metalman
    That's great xsmini...... "It just keeps on ticking".:D
  4. Justa Jim
    These are the kind of posts I like to see. :Thumbsup:
    Sure hope I can see the same. Then again at my current avg of 1100 miles a month over the past 49 months that will take close to 18 years in total to accomplish.
    Great!!! :Thumbsup:
    I'm headed for just about 90,000. xsmini you are an inspiration to me & my MINI.
  7. Minidave
    My '09 Clubby just turned 2 years old, and I have just under 30K on it, so I have a ways to go to hit 100K, but I'll get there!
    OTOH, my wife's Audi bought new in Dec 2003, now has 48K - she does less than 7k a year, and that includes trips to either coast we've made, plus several to neighboring states!
    I hope we don't start seeing $5/gal gas and higher, or some of these high mileages won't be happening in the future, it will simply cost too much to go!
  8. MinixB
    MinixB Member
    Jul 14, 2009
    269
    14
    Female
    Graphic Account Specialist
    Kansas City, MO
    My MINI is a year and a half old and he's almost to 33,000 miles :)
  9. Wadodude
    Wadodude New Member
    Aug 31, 2010
    42
    Programmer
    The colony
    Wow what an inspirational mini!! I wonder how you drive xsmini and do you have any mods on your car? Not that you need any.. just wondering. Original clutch:eek: I have 37,000 miles on my 04 MCS.
  10. xsmini
    xsmini Member
    May 27, 2009
    46
    20
    Bishop, Ca
    I drive and play hard when I need/ want to, but most of it is commuting, so a lot of highway miles.......
    Some mods, nothing too drastic, its been awhile since I thought about it lets see what I can remember
    -Alta CAI
    -M7 Coils (sits about 1 1/2 inches off the ground)
    -15% pulley (put on at about 30k)
    -Coil
    -Plugs
    -Wires
    -OCC's (2)
    -M7 DFIC
    -some other little M7 carbon fiber piece that goes in front of the radiator (looks cool ;)
    -Webb Motorsports rear swaybar and endlinks
    -Rear control arms
    -powerflex bushings
    -Alta Exhaust
    I'm sure there is more, I just can't seem to remember right now.
    Nik
  11. lotsie
    stagehand/part time detailer
    Right here
    For me, even at 5 bucks a gallon, I'll motor rather than fly for vacation.
    I'll be in Atlanta for close to 2 weeks in June for work, but rather than fly, I'm going to drive. I'll be downtown, and Poco will hopefully be residing at Ways shop:D
    Mark
  12. Wadodude
    Wadodude New Member
    Aug 31, 2010
    42
    Programmer
    The colony
    Cool! I'm looking to do a lot of traveling on the weekends. Is it weird that I look forward to putting a lot of miles on this mini? ..Heh. Also I bet that cool looking piece is the air plate diverter.
    Mini motoring!
  13. lotsie
    Right here
    Look what just happened to Poco.
    Mark
  14. Nathan
    Had me a bit worried there lotsie. With the storms y'all just had and all I sorta expected the worst.
  15. lotsie
    Right here
    Thanks Nathan! Worst of it missed us. For those of you metrically challenged that's 111845 miles.
    Mark
  16. Justa Jim
    Go Poco......Go Poco....Go Poco. :Thumbsup:
  17. geowit
    geowit New Member
    Oct 13, 2010
    15
    PA
    Pic says it all.
  18. Stinker
    Stinker Active Member
    May 16, 2009
    237
    117
    USPS Maintenance Mech
    Smithfield, VA
    We have had 5 MINI's. Does it count that they add up to over 100,000 miles.
  19. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    Just rolled over this morning, 115,000, oil change this evening.
  20. xsmini
    xsmini Member
    May 27, 2009
    46
    20
    Bishop, Ca
