I still have a small supply of Poly D pads for any MINI owner with the Wilwood DP caliper shod brake kit. These were a custom run pad as D is not available in that pad config. Poly D is a great AutoX pad with a moderate bit and low temperature application. When stock runs out it's not likely I'll run more of them due to costs. Normally $95, I'll knock them down to $85 to move them out.
Would these work good as street pads also? I currently have BP-10's and I believe my calipers are the DP6
They'd be 'ok' for street but being metallic they make more noise. Biggest issue however is they are not available for the DP6 set up only the conventional radial mount four pot.
