Engine Drivetrain 1st Gen Cooper S Look Verrrrry closeley
Discussion in 'Tuning and Performance' started by Eric@Helix, Apr 17, 2012.
  1. Justa Jim
    I'm glad you posted this, because I don't know either and thought I was the only one. :D
  2. Jason Montague
    :cornut: (to me) It appears to be a turbo charger connected to the exhaust pipe of a MINI. I thought that this far from the exhaust manifold that the turbo would be useless and just cause excessive back pressure and none to speak of intake pressure. But then I'm not a trained performance gear head. I could also be totally wrong.:Thumbsup:
    I'll ask the questions not being asked...
    Why a rear mount for the turbo, won't the pressure losses be large in moving air to the front of the car?
    What about turbo lag. With BMW and the like moving to multiple small turbos as close as possible to the exhaust ports to minimize lag and increase efficiency won't a turbo way back at the end of a MINI have a lot of lag?
  4. minimark
    #24 minimark, Apr 19, 2012
    They make rear mount turbo systems for corvettes and other cars and all your concerns are there but if this is a twin charge system, the SC should take care of any lag, whilst the turbo builds pressure for the top end... 2 cents
    Look forward to seeing how this works out!!
  5. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    #25 BlwnAway, Apr 19, 2012
    Same question I had Nate, but if it is a T/C system you are are going to have boost limitations due to the S/C bottleneck, so to speak, so taking that into consideration with the right turbo you sould be able to compensate for the loss and possibly all that travel will actually cool the air even that much more?
    Hell I don't know, I'm basiclly just spit-ballin' here. :lol:
  6. minimark
    If doing a Twin Charge, mounting it in the rear would also get it away from the heat and tight confines of the engine compartment.....
    Just spit balling here too....:p
  7. BlwnAway
    Nov 24, 2011
    474
    290
    Lol, we might finally have a situation where the +'s start to out weigh the -'s.
  8. Jason Montague
    :cornut:Isn't that what I said above?:cornut:
  9. Metalman
    7,700
    Yeah but.... When you said this.... "But then I'm not a trained performance gear head. I could also be totally wrong"..... it cancelled everything out.....:D:D:D
  10. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    It is indeed a rear mounted turbo.
    For those who are going to the dragon, It'll be there Friday and Saturday. The basic setup is a slightly larger-than-stock supercharger pulley (not smaller, like most people have), Tied to a race header and custom exhaust which spins the turbine in the rear. From the compressor side of the turbo, there is a charge pipe that sisters to the exhaust moving the compressed charged forward to the intake. By putting the turbo in the rear, we can package a much larger scroll, and separate the heat that it produces from the engine bay. The relatively long charge pipe would normally contribute to turbo lag, but that's what the supercharger is for. We're still playing with pulley sizes to reduce lag. Needless to say, the car scoots.
  11. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    So if the turbo is in the rear where did the Flux Capacitor go?
  12. minimark
    ...in the doors, its a race car!! LMAO:D
  13. eMINIparts
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    ohhh its all making sence now
  14. Justa Jim
    So it is kind of based on the jet engine principle, where the exhaust gas turns the turbine which turns the compressor, but minus the after burner?
  15. Metalman
    7,700
    You can still inject gasoline and get flame thrower errrr after burner.... Heh Heh Heh....:devil:
  16. Eric@Helix
    1,257
    Shepherd
    Philadelphia
    Well yes, and a turbo can somewhat easily be converted into a cobbled-together jet, much like this vid:
    [ame]http://www.youtube.com/watch?v=BZoymnZRBVc[/ame]
    BTW, I love how this guy has it going in his garage (indoors) and it's just pissing some sort of liquid all over the place. Hopefully it's coolant and not jet fuel.
  17. Justa Jim
    Now that would be cool. Come through the corner with the super charger, then go to full military power, hitting the AB on the straight away. :Thumbsup:
  18. BlwnAway
    Nov 24, 2011
    474
    290
    The tags at the bottom of this thread should say coool verrrrry instead! Can't wait to see & hear what this sounds like.
  19. Eric@Helix
    1,257
    Shepherd
    Philadelphia
    Well, we just fitted a 'One Ball' of sorts. Welded in a stock silencer 'cause that car was just too damn loud for a 725 mile road trip to the dragon. If all goes well, we'll toss her on the dyno today. BTW, the little bit of back pressure that we presumably got from the muffler has improved torque.
    Car will be at the Dragon Friday and Saturday.
  20. KittyMini
    KittyMini Club Coordinator
    1,183
    You go with your bad-ass Franken-Savage self :cornut:
