1st Gen R53 Cooper S Looking to add more speed
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by shaunt18, Aug 16, 2010.
  1. Thumper460
    Thumper460 Active Member
    May 26, 2009
    559
    94
    United States Navy ..Retired
    Nate your rock.... so have you tried one?? Some times the simplest solutions are a better solution..yes??
    YES.. as soon as I can dig up some more info.. and how much ign timing/ a/f is changed and how...( tricking the IAT is cool... as long as it doesn't kill it !! LOL) Remember I am at 220+ WHP with NO TUNE!! I have to talk to my dyno man, and fix my bad O2 sensor.. then for sure I'll give it a try. And then , it seems , I will be the only one!! LOL
    Just me................................
    Thumper
  2. lotsie
    stagehand/part time detailer
    Right here
    Cheapest bang for you buck is a real good set of tires.
    Mark
  3. Justa Jim
    Thanks buddy. I thought that whirrly-gig thing was cool, like maybe a supercharger for a Cooper. Of course it could only spin as fast as the air already entering the intake, so I was curious how it could help. :crazy:
  4. Rooster
    Rooster New Member
    May 22, 2009
    Systems Engineer
    West Hollywood, CA
    Agreed. Freeing up HP is as good as (if not better then) adding HP to the mix.
    If you're still running the runflats, ditching them will help a lot!
    And lightweight rims AND tires? Even better, but that's usually more $$$.
    For example, my buddy has about 25 or 30 more HP then I do.
    When he's on his heavy stock wheels we're about equal to me on my lightweight wheels.
    When we're both running equivalent rims/tires he walks away easily from me at freeway speeds.
    :Thumbsup:
  5. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    Call us and we'll be glad to help with some good info, this thread seems not to be very useful.
    WAY
    317.201.8670
    Way Motor Works
  6. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Joking aside the basic fundamental approach to the least expensive hp gain is a thorough tune up and running gear evaluation. I have seldom ever seen MINIs having new performance parts installed and a dyno with ECU tune with this simple task accomplished?
  7. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    There you go... Being all reasonable...
    cheap and easy power. Put on a pulley. Then save your money for some of the things that really work. Look a CAI costs what $100-$200 and gets more sound than power. That's a big step towards a tune or a head. About half the cost of a camshaft.
    IF there were tons of cheap power on the car, it wouldn't cost a lot to get tunes, headwork, or other stuff. Because of knock sensor technology, pretty much all engines deliver more of thier potential without spending big money. All the nice and easy bolt ons, at best, give a bit of a bump. But when it comes to the basics of making real power, more air in, exhaust out and more pressure on the piston when it counts, there is little new under the sun.
    The absolute best way to make any MINI faster is a touch of suspension work, and driver training. Tighten the nut behind the wheel.
    Oh, and an Ian Cull circuit from FES. No first gen is complete without one!
    Matt
    ps, Mike, I've posted some real knowledge in the other chip thread.
  8. Thumper460
    May 26, 2009
    559
    94
    Thanks Dr. but I always like to advise on what I have done/ used/ am using... cool??
    Thus the question has anyone USED or are USING the G force Chip. All the theory in the world can be a bit different than rubber to the road.
    Dont get me wrong here.. all you and others have said is a good thing.... except no one who is using the G Force has told there experience. It is all conjecture and theory, yes??
    As for cost... hell the schrick is a 7 hp gain and is 400.00!! there are high dollar headers out there that might be good for 10 whp. This platform ( the MINI) is full of hype and mis directed opinions on performance parts.. thus the NEED to actually experience the benefits. Cool??
    Yes.. I have one and Yes, I will test it.. I was just curious as to others RESULTS, but it seems there are none. LOL
    CAI is the first I would do.. HP increase is small but the sound is priceless!!
    Same with a 1-ball or a cat back.. there is again a bit more power, however the Sound rocks!!
    Power?? easiest way is one of two camshafts designed for the r50/r53s that work great with OUT a tune.. NS1 and NS2. They can be installed in a few hours, or at least a sat.
    Pulley.. needs puller and a bit of a hassle.. but good for an easy 20-25 WHP!
    Head.. there are now a few to choose from, usual bolt on power is 23-28 WHP ( with out tune)
    Header.. and gasket matched intake.. a few more ponies, but now you are starting to pull everything together. Headers with cat. 8-10 WHP / Matched intake 5-10 HP
    Tune... "they say*" 20-30 WHP I see an average of 12-20 whp. I actually am SWAGing this as I am STILL un tuned. (* from posts on forums)
    Of course all this is BS , as these cars are soooooo different in ECU and years of manfg. but it is a good guide. ( lol yes I dyno'd ALL my mods befor and after..LOL)
    Hope this helps.. and I didnt step on any toes.. LOL
    Just me.................................
    Thumper
  9. lotsie
    Right here
    Seems we either totally confused, or frightened away the OP.
    Mark
  10. Thumper460
    May 26, 2009
    559
    94
    LOL.. actually the question I posed was pretty straight forward, yes??
    Who uses or used it and what are your findings... !!
    Seems there are no one on this site, and I am the only one!! LOL
    SOooo... when I get my O2 replaced, I will try it on my un-tuned 06.
    Just me...................................
    Thumper
    PS: if the thing does NOT work, you just un plug!! and the ECU go back to where it was.
    Tpr
  11. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Please...
    if you want to keep going on this chip gizmo, post in the thread about it! That isn't hard. All one has to do is choose to put content there.
    Matt
  12. Thumper460
    May 26, 2009
    559
    94
    LOL... I didnt know about the other post...lol
    Thumper
  13. shaunt18
    shaunt18 New Member
    Aug 9, 2010
    Adding more speed
    My mini is a 2003 cooper s, and I meant cheap as in a range of $1000 or less.
  14. shaunt18
    shaunt18 New Member
    Aug 9, 2010
    this goes along with the (adding more speed) would an intake, exhaust, supercharger pulley help with speed?
  15. lotsie
    Right here
    Good to see you back again:D Has this thread helped you?
    Mark
  16. Thumper460
    May 26, 2009
    559
    94
    Pulley... 1-ball, NS1 Camshaft..( 200-250 installed- 35.00-40.00 - 450-500.00 ) should be under your 1000.00 sound better and go faster..
    Just me......................................
    Thumper
  17. lotsie
    Right here
  18. Thumper460
    May 26, 2009
    559
    94
