Loss of all gears
Discussion in '2nd Generation: 2007+ R55 through R61' started by Furnitureman, Mar 10, 2021.
  1. Furnitureman
    Furnitureman New Member
    Mar 10, 2021
    2009 Clubman JCW manual transmission.
    I was driving this morning changing gears as usual and all of a sudden I heard a pop and the car was coasting. No 1-6 gear or reverse. I finally had a closer look at it and it seems that the linkage is working. The clutch moves the linkage on the transmission housing and the gear changer changes the gears on the transmission housing. All of that seems normal so I don't believe it is the linkage lines going from the trans to gearbox. All of that seems pretty tight. It must be something internal. Anybody have any idea where to start? Someone suggested maybe the CV axle is broken?
  2. Metalman
    Start by inspecting both axle shafts.....
  3. 00Mini
    2,259
    Welcome to Motoring Alliance and keep us posted on what you find.
  4. MCS02
    6,315
    Welcome to MA. What @Metalman said. Let us know what you find.
