Engine Drivetrain 1st Gen Cooper S LSD or not?
Discussion in 'Tuning and Performance' started by UKXPAT, Nov 16, 2010.
  1. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Engineering speaking for the MINI... not really. It all depends on how you drive the vehicle. Fundamentally the locking devises that are available the ones that can actually tailor to the driver/car ability to reduce or increase traction in any predetermined fashion need to be adjusted for the specific needs. There are only three that I know of on the list mentioned in this thread capable of such adjustments? And all would require the removal of the devise to do the adjustments for optimum use.
  2. ScottinBend
    Torque steer is generated by the unequal length driveshafts, not from an open diff.
    Boy if a slip eliminates torque steer mine must be broken. I'm sure it helps, but it is very dependent on road surface & steering angle. So my answer to the question is no a LSD does not eliminate torque steer.
  4. Dave.0
    Ok guys the question was will it reduce torque steer.... NOT Eliminate Torque Steer.
    You guys keep trying to turn every comment into a NAM argument thread. :mad2:
  5. ScottinBend
    An LSD will not reduce torque steer. Torque steer comes from un-equal length driveshafts.
    An LSD will only come into effect if one of the wheels looses traction, you don't start out with both wheels having power (unless you are using a locker diff). When a wheel looses traction the LSD then will transfer some power to the other wheel.
  6. Metalman
    I don't intend to hijack this thread....
    But, in the case on the 2nd generation, MINI is apparently using a software up-grade to modify the performance of the e-diff to control torque steer.
  7. ScottinBend
    It does that by applying the brake to a particular wheel. Kinda like the traction control.
  8. Metalman
    Correct. :D
  9. UKXPAT
    UKXPAT New Member
    Nov 12, 2009
    143
    Crystal Lake, IL
    Anyone know of a decent 'how to' for an LSD install, preferrably with lot's of pictures?
  10. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    One with a few photos of both Quaife and OS Giken. [ame=http://www.lonestarminiclub.com/forums/showthread.php?t=464]Clutch, Flywheel, and Quaife Overview - Lone Star Mini Club Forums[/ame]
    For the R56, with a few more details about securing the differential ring gear. http://www.motoringalliance.com/library/2nd-generation-mini-cooper-how-to-4/r56-clutch--lsd-installation-overview-84/
  11. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    Nitro, are you holding a political office? That is a very long "Yes!"
    :D
    Great info in this thread. Thanks for all the input!
    :Thumbsup:
  12. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    Which of our lovely vendors has good prices on the O.S. Giken?
  13. k-huevo
    159
    Pipe Creek, Texas
    Werkin Mini sells OS Giken products.
    Unfortunately, due to poor exchange rates, prices increase ~12% on January 1, 2011
  14. minimark
  15. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    So you want me to buy one tomorrow? :p
  16. k-huevo
    159
    Pipe Creek, Texas
    That would be nice.
  17. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    #77 M^Cubed, Dec 29, 2010
    Jinx'd myself! crap
  18. GreyLens
    GreyLens New Member
    259
    71
    Electrical Engineer
    San Antonio, Texas
    I got my OS Giken through Werkin Mini and they installed it as well. Excellent results. I highly recommend the product and the provider. And the price will continue up for many many months so waiting will only cost more.
  19. minimark
    OS Giken rocks!!!!
    Revolution Mini Works is also an authorized dealer for their products..
  20. 00zero
    00zero New Member
    Oct 2, 2009
    92
    Pittsburgh. Pa
    i know this is off topic.
    Is there any difference between the OS Giken and a Torsen unit other than tune-ability of the Giken and the torsen being an open diff when a wheel lifts?
    will there be any difference on a daily driver other than on a sheet of ice perhaps?
    -jonathan
