Made One Of These Today
Discussion in 'General Chat' started by Metalman, Feb 15, 2011.
  1. Metalman
    Oh yeah.....
    Well check out the 5mm wheel spacer justa the left of the stack of tires...:D
    So ya going with some 28" DUBs..... :D
  3. Metalman
    Damn.... Secret's out.... :D
    Sorry to spoil your surprise. Make some moon wheel covers & then pull them off to everyone's amazement. :cool:
  5. Metalman
    Bang.... Installed by the home owner today...:D
  6. Dave.0
    WOW ^^^ :Thumbsup:
    Must not show my wife. :frown2:
  7. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    MM is sweet. What's something like that run? Ball park figure
  8. Metalman
    That particular job was $3,700.... And since it was homeowner install friendly, they saved some $... By buying direct from me and installing it themselves they are able to save 30% - 50% over conventional means....:D
  9. BRG_Paul
    BRG_Paul Active Member
    Nov 20, 2011
    758
    184
    Turbomachinery Engineer
    York, PA
    #389 BRG_Paul, Apr 10, 2014
    I've been working on this for over a year and finally started it up today.
    5600 hp centrifugal compressor. It's just like the R56 turbo....but just a "bit" larger at 12,400 Lbs. About 5X the weight of a MINI.
  10. Metalman
    Nice....
    So how big is the intercooler....:D
  11. BRG_Paul
    Nov 20, 2011
    758
    184
    York, PA
    #391 BRG_Paul, Apr 11, 2014
    92 inches in diameter and 22 feet long... It's big. And the compressor has a 20" suction line.
  12. agranger
    Meh... My supercharger makes more power than that. I've got the dyno graphs to prove it but, well... um... my scanner is broken! Yeah! that's it! My scanner is broken.
  13. BRG_Paul
    Nov 20, 2011
    758
    184
    York, PA
    Well... A year in development and now after three hours of testing I can see that the bearings are running hot. Time to pull it apart for tweaking... Sigh....
  14. Minidave
    Bearing alignment issue?
    We used frickin lazers to align bearings in big equipment at my plant.
  15. DneprDave
    #395 DneprDave, Apr 12, 2014
    Frickin Lazers! :lol::lol::lol:
    Dave
  16. BRG_Paul
    Nov 20, 2011
    758
    184
    York, PA
    No, the bearing alignment is good... The housing is line-bored to 0.0005" true position (regardless of feature size). It's the bearing to shaft clearance that I need to modify. Normally I design for a diametral clearance of 0.0012 inch/inch of shaft diameter. The shafting is ~5" in diameter. But my tests are indicating high shearing loss and reduced oil flow. So I am opening up the clearance by 0.004". ..(0.0016 inch/inch of diameter). The increased clearance will reduce the shear and also increase the mass flow of oil. So the bearings will generate less heat and the increased flow will help to carry the heat out of the bearings too..
    The lubricant is a mixture of refrigerant and polyolester oil (POE). The refrigerant tends to flash out of solution at low pressure zones in the bearings...(bad). And due to the 2-phase flow characteristics, it is very difficult to computer model. So this week I'll try to dial in the performance by experiment. This is going to be a long week.
  17. Metalman
    Well.... Don't cook the bearings....
    You can always take away.... Harder to put back...:Thumbsup:
  18. BRG_Paul
    Nov 20, 2011
    758
    184
    York, PA
    Absolutely.. It is like getting a haircut. It's easier to get it cut off than to put it all back on...
  19. Minidave
    What are you pumping, ammonia?
    Aren't they roller bearings?
  20. BRG_Paul
    Nov 20, 2011
    758
    184
    York, PA
    R134a (the same as in your car)..... not ammonia. And the journal bearings are fluid film type with tilting pad thrusts ... Each bearing in my compressor sees 9,000 pounds of radial load. Rolling element bearings cannot handle the load and speed ...plus they are life limited.
