Made One Of These Today
Discussion in 'General Chat' started by Metalman, Feb 15, 2011.
  1. Metalman
    Those two mufflers would be snickering at me if I did that... So no....
  2. Minidave
    So, you have a slip roller big enough to round those out? Why do the ends look like they've been heated? Is that from when the pieces were cut out from the larger sheet?
  3. Metalman
    I have 5 rolls in the shop with varying capacities. Some can handle material up the 5/8" thick and some can handle sheets up to 120" wide.
    The color banding is from the mill and is typical of ASTM A 1011 HR steel from their cooling process.
    That color banding becomes a desirable attribute when some of the residential pieces get clear coated...
  4. Metalman
    Made a piece of lawn art for my lovely wife today...:cool:
    Does it feed the deer too?
  6. vetsvette
    Awww. :eek:
    Pretty cool actually.
  7. Metalman
    Thanks Vet...
    She want's me to have it powder coated "Chili Red"....
    I asked her why.... Doesn't she know "DARK SILVER" is the fastest color and RED is what they color stop signs?...:D
  8. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    Imagine the turbo lag. Press the gas pedal at 10AM, and at 2PM you launch like a freaking rocket.
    CD
    The trick with that is NEVER lift. :arf:
  10. Metalman
    The red guy showed up from the powder coater today...
    Planted it outside the sunroom...
    The wife was very happy.... I got major points for the effort...:D
    I also noticed I need to mow the grass....
  11. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    And you can't use the old...
    "But honey, the lawn mower blade needs to be sharpened" excuse.
  12. Metalman
    Nope.... That wouldn't work...:D
  13. DneprDave
    But it's true!
    I just sharpened the lawnmower blades and it doesn't bog down like it used to!
  14. BlwnAway
    Nov 24, 2011
    474
    290
    #714 BlwnAway, Jul 6, 2016
    Absolutely, I joked with a friend once that my blade was so dull, I wasn't cutting the grass, I was just beating it into submission.... :D
  15. Metalman
    Just finished up with a stainless steel 24 beer tap station...
    Customer will pick it up today...
    Doing our part to fight the local war on thirst...:beer
  16. mrntd
    Who's it for? We'll have to make a road trip to check out their selection once it's installed.
  17. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    3d Printing is fun!! No more damn seatbelt chime!
  18. Metalman
    The sheet metal shop is starting to smell like a wood shop.... And that's not necessarily a bad thing...:D
    Got two counter-top orders from a client last week... One cook top and one sink bowl top...
    Something a little different than what we normally do.... They are both called "Waterfall" counter-tops, so the surface will turn 90 degrees and go to the floor on one end of each top...
    Overall thickness will be 4", so it will look like a 4" thick slab of SS when finished...
    I had to design a ladder tube frame structure to get the weight out and yet be strong and not flex...
    Today's pictures...
    Looks good Chuck. Remember to not weld the wood. If you do weld use a dowel rod with the stick welder.
  20. Metalman
    Just finished up the Waterfall Counter top for the range...
