2nd Gen R55 Clubman Magnaflow exhaust
Discussion in '2nd Generation: 2007+ R55 through R61' started by rum4, Dec 28, 2011.
  1. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    I just installed a Magnaflow exhaust with a 3" pipe from the catback and it drones unbearably. Would a resonator or 2.5" pipe take some of the drone out? It drones badly around 3k rpm at around 4k rpm it is fine. The drone on shifting thru the gears and on let off of gas pedal is terrible if not at 4k rpm or higher.
  2. CHKMINI
    I too had a Magnaflow on my '04 and the drone was loud. From what I researched I either had to replace the exhaust or live with it. I lived with it for 106,000 miles before selling the car. Huh....what did you say?
  3. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Note sure of the narrower pipe would help the drone but a resonator would help some.
  4. rum4
    4,568
    1,475
    SC
    back to stock now, couldn't handle the drone with my hearing as it is... Thanks for the above info...
  5. Redbeard
    1,636
    398
    I'm looking at exhausts for my MCS and I was wondering which Magnaflow system you had on.
    Everything I have read about Magnaflow exhausts on MINI's says they are loud & drone. Hope you find something that you like more. I'm not sure what the best setup is for an R56. Hopefully someone will be able to chime in with the answer to that.
    For my R53 I found the JCW was the sweet one. Maybe a JCW for an R56 would suit you.
  7. rum4
    4,568
    1,475
    SC
    #7 rum4, Dec 29, 2011
    I am not sure I bought it used from someone else. It has a 3" inlet, two exhaust and 4" tips. Sounds good on the outside.
  8. shipjumper
    shipjumper New Member
    Apr 13, 2013
    toyota servicewriter
    graniteville, vt
    I just installed a borla on my non-s. Under light throttle there is a hummmmmm that fills the cabin, but on flat highway at 70 its whisper quiet. When throttle is applied it does get intrusive. Im 70% happy i did it.
  9. Stinker
    Stinker Active Member
    May 16, 2009
    237
    117
    USPS Maintenance Mech
    Smithfield, VA
    I have the Magna Flow on my '10 Clubman and have no problems with the sound.
  10. rum4
    4,568
    1,475
    SC
    The one I had purchased was off a 2010 so not sure what changed between the '10s and 11's but it droned bad.
