1st Gen R50 Cooper Manual Transmission Fluid
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by zman70, Aug 11, 2016.
  1. Canusrufis
    Canusrufis RMW Powered R53
    210
    107
    Winston Salem NC
    Eneos worked better than Redline for me. The redline stuff was too thin or got thin with use (35k). Eneos go rid of some 2/3 grinding. First think I noticed after the change. good luck.
  2. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    #22 cristo, Aug 17, 2016
    I have some data from Blackstone on MTL, MTF-94, and MTL LT-3
    from a couple years ago when I had some oils analyzed.
    The MTL had 3118 ppm Zn, the Texaco MTF-94 had 1712 ppm, and
    the LT-3 had 1021 ppm. The LT-3 sample probably had some
    residual MTL mixed in with it, so there's probably less Zn in
    pure LT-3. The viscosity of MTL was about 9.8,
    MTF-94 10.2, and the LT-3 with a little MTL was about 7.2.
    LT-3's measured viscosity is about 6.1.
    I don't have Blackstone data for D6, but it's supposed to have
    viscosity of about 6.4. Its label indicated that it's
    designed for both auto and manual transmissions fwiw.
    Have people had problems with the 7/2004 - 2006 non-LSD
    6 speed Getrags and 5-speed Getrags that come
    factory filled with BMW MTF-LT-3?
    LSD Getrags from that time period were filled with MTF-94
    because MINI found that LT-3 + factory LSD caused some
    increased noise.
  3. Metalman
  4. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
  5. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    #25 cristo, Aug 17, 2016
  6. ZippyNH
    Good info...
    Actually mirrors what's been happening in trucking....
    To improve mpg, some be truck trannys and rear differential are now using 5w-30....factory filled....and operators are seeing a HUGE reduction in life....the push...lower fuel burn to increase mpg, and lower co2 numbers.
    Makes me wonder if the thinner fluid was to try to get the tiny gain in fleet fuel economy...fractions here and there add up...
    Actually I think that is WHY BMW SELLS MINI's...to cancel out the big low mpg cars they sell to make averages look better...
    There was an open thread of a guy who used the d6, and noticed it changed color and smelled "brunt" in a few miles....not sure what the age of his car was.
    This does remind me of a Honda CRX HF I had....went to change the tranny oil, and found in the book it was "lifetime" filled.b it 5w-30 motor oil was the replacement oil if needed..lol...back in 2003 or so on a 1989 car....ended up using Mobil 1 5w-30 but added extra zinc cause I simply did not trust the lifetime fluid, but also did not believe a regular oil was good enough....but could not helping myself to add a very heavy MTF ... partially due to MPG.... I was routinely getting 50 mpg in that car, and that was great considering I was in the Colorado Rockies going back and forth from Denver to various places, both highway and back roads.
  7. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    Lol... guess I made an even swap then...
    Went to a lighter flywheel and a heavier transmission/diff oil.....
  8. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    #28 cristo, Aug 18, 2016
    I've been mulling over this topic for a while.
    My vested interest is that I have a 2003 R50 with a Getrag 6-speed conversion
    (after a failed Midlands) filled with Redline D6 (shop's choice and recommendation).
    I'm a little wary of the low viscosity of the fluid, but I'm really not convinced that
    it's a worse choice than the BMW MTF-LT-3 that is called for in a 2005-ish 6-speed Getrag.
    The LT-3 has even lower viscosity than the D6 (slightly) and is also not fortified with zinc.
    In a daily driver Justa, however, I'm not pushing the limits of this robust transmission much,
    and although I have a LSD installed, it's a Quaife, not the factory LSD, and doesn't really need
    a thicker fluid to run properly and quietly.
    Other thoughts:
    Dave mentions the Amsoil Severe Gear fluids, but the 100C viscosities for those are 16, 21, and 26,
    which may be great in a track or road warrior MINI, but even the lowest one seems pretty thick for a
    daily drive MINI.
    Amsoil's site actually has no formal recommendation for a Getrag 5 or 6 speed except stick with LT-3.
    Royal purple actually recommends their Max ATF fluid for a Getrag 5 or 6 speed..
    I can't find specs on the Eneos GL5 75W90, and they don't have a formal recommendation for MINI, but
    I'm guessing this is the appropriate choice. Anybody have info? The Eneos site says "info coming soon".
    Fuchs Titan Sintofluid 75W80 with a viscosity of 9.4 looks like a good choice.
    Anyone running this?
    Redline MTL and Texaco MTF-94 both look like good choices, although I'd like something just
    a little thinner with our cold winters (like maybe the Fuchs above).
    The person with the possibly burnt D6 fluid had been towing a 1,000 lb trailer with a Justa
    with a Getrag 5-speed (maybe not up to the job).
    I'm sticking with the D6 for now, but am thinking of sending a sample of the now 2-year old
    fluid to Blackstone for analysis and rethink after seeing how it's holding up.
  9. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    #29 cristo, Nov 10, 2016
    Sent in and got back an oil analysis for the D6 at 16,300 miles after installing the remanufactured 6-speed Getrag.
    Aluminum and Iron are about 50% higher than the universal averages given by Blackstone, and viscosity is only
    5.7 (supposed to be about 6.4 new) at 100C.
    Based on this, I'm going to drain and refill with Fuchs Titan Sintofluid 75W80 later this month when I have the time.
    Their site indicates it's recommended for R53's with or without LSD, and it's about 10% less viscous than Redline MTL
    or Texaco MTF-94, but way higher than D6.
    Since I'm well past the initial higher wear period of a new transmission, the refill should be good for quite a while.
    The analysis is linked below. Ignore the second and third column and most of the comments, as they refer to another
    analysis with a different oil in a different transmission (blend of LT-3 and some leftover MTF-94 in the old Midlands).
  10. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Changed the D6 to Redline MTL today.
    I already had some on hand, and the Fuchs is still on order, and I'm still waiting to hear about some compatibility issues from
    technical support at Fuchs and MiniMania since it's a GL-5 spec and I want assurance that
    it's ok for yellow metal synchros, etc. Their website implies that it is without stating it outright,
    and a few other sources of info indicate that it's ok.
    If I have no winter weather issues, I'll just stay with the MTL. If I do, I'll swap to the Fuchs later.
  11. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Interesting finding:
    Since installing the 6-speed Getrag, I've often had a minor chatter on letting out the clutch
    just after starting up the car, it goes away after a block or two, and I thought it was just
    some minor clutch chatter, but since changing from D6 to MTL, it has gone away completely!
    Maybe the thinner D6 and the Quaife don't play well together from a cold start.
    Also, MiniMania recommended MTL and wouldn't vouch for Fuchs Titan Sintofluid for this application,
    and Fuchs hasn't responded to my inquiry, so it looks like I'll be staying with the MTL.
    We've had some 30F mornings and no shifting problems with the thicker MTL.
  12. Dave.0
    When I have my clutch done this winter I am filling it with the BEST because when I do drive my car I beat the snot out of it.
    I have run AMSOIL and had no issues at all.
    Motul 823511 Gear FF Competition 75W140 100 Percent Synthetic Ester Based Racing Lubricant for Limited Slip Differential (LSD) - 1 Liter $25.00
  13. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Wow. That's thick stuff.
    https://www.motul.com/system/product_descriptions/technical_data_sheets/108/original/Gear%20Competition%2075W140_GB.pdf?1290086772
    I take it The Mistress doesn't do a lot of winter driving.
    BTW, a tip for getting the gear oil level right for those of us that do things curbside.
    I usually use ramps for engine or gear oil changes which is great as it puts the drain hole lower,
    but it leads to underfilling the transmission in this position. I guess I could put the front on
    ramps and the backs on jack stands and try to match the position, but the following approach
    is easier and pretty foolproof:
    Jack up the front passenger side to a jack stand, remove the fill plug, and fill until just dripping.
    Leave the plug out and jack the MINI back down level with something to catch the overflow
    (turns out to be just a few ounces), then back up and put the plug back in at the correct torque.
  14. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    I found increased wear metals and a drop in viscosity with D6 as the initial fluid in a
    remanufactured 6-speed Getrag after 16,300 miles. Not horrible levels, but about
    50% above expected for iron and aluminum, and 10% drop in viscosity.
    This is in a Justa (2003 R50) that doesn't see any autocross, track driving, or other abuse.
    I changed to MTL last weekend.
    I expect to see about 1 mpg or so drop from the change.
  15. MCS02
    I use Redline.
  16. DneprDave
    I only use real maple syrup.
  17. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    That's wise, as I'm certain that artificial maple syrup would cause some problems.:smilewinkgrin:
  18. Dave.0
    She goes out in the Winter without any problems at all. I do not daily drive my car because I work from home but she does sleep in a warm carpeted garage. :ihih: I wish I did drive everyday because the car is so much fun to drive. :Thumbsup::devil:
    It may be a "tiny" stiff for a few min but once its warmed up it is no difference at all. Also it is the fluid OS Giken recommends for the Super locker LSD that going in my car along with my new clutch.
    If that is what the diff maker says it's what it needs. :yesnod: You can use real maple syrup for the clutch slave. :)
  20. RallyMini370
    Hey Dave, thanks for the info on the oil. I use Redline 75/90 now but that 140 weight appeals to me due to it's always baking hot down here. I'm going to see if they have it in the local speed shop.
