R56 Mass Airflow Sensor
Discussion in 'Tuning and Performance' started by Homazur, Oct 6, 2020.
  1. MCS02
    Hope they were good results
  2. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    #22 cristo, Oct 24, 2020
    More curbside repairs at home
    New MAF the other day
    Didn’t fix 2B5C (P115C) code
    Today: New throttle body and also removed
    intake and looked at the intake valves
    They had a layer of black crusty stuff
    but not too bad so I hit them directly
    with some Seafoam spray and a compact
    toothbrush then some canned air 2 intakes
    at at time, turning the crank in between
    so I was working on closed valves.
    All back together now, Seafoam smoked
    out, and the code isn’t coming back
    whereas it was happening every time I drove the car before.
    It’s nice when things go right.
    Yay!!
    I think the problem was with the throttle body.
  3. Homazur
    Homazur Well-Known Member
    Sep 25, 2020
    234
    279
    Question for anyone my R56 I’ve been using 93 octane is that overkill or is 89 or 87 recommended?
  4. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    I would recommend 91 or 93.
    I use 93, usually ethanol free.
    I have always run 93 in our MINI's. Your car will pull timing with a lower octane fuel. Less power, but I don't think it will hurt itself.
    Is your MINI a Cooper S or a non-turbo Cooper?
  6. Homazur
    Sep 25, 2020
    234
    279
    It’s a sleeper R56 base hatchback ~~
    • Like Like x 2
    • Winner Winner x 1
  7. Homazur
    Sep 25, 2020
    234
    279
    So update no walnut blasting because it’s base model just the the two VVT solenoids changed and everything else checks out pickup is tomorrow and see how everything turns out~~
  8. 00Mini
    :Thumbsup::Thumbsup:
  9. MCS02
    Sorry I thought you had an S
    Cooper's are great MINI's enjoy it! :Thumbsup:
    Another great thing is it does not have direct injection. No walnuts needed, but I would run a bottle of Chevron Techron through every now & then to help keep things clean.
  11. Metalman
    Mass Airflow Sensor...
    I wonder why the Catholic church needs this information.....
  12. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Can you use a censer to do a smoke test?
    :rolleyes::D;)
  13. Homazur
    Sep 25, 2020
    234
    279
    Here we go! So VVT both changed and running great for two days and all of a sudden check engine light again! Weird thing it’s running good and idling good? Hmm so I pulled 3 codes in history but no new code will check with shop! Oh and also the Chevron Techron as suggested ~~
  14. Homazur
    Sep 25, 2020
    234
    279
    That's interesting, let us know how it goes.
  16. 00Mini
    Hope you find the problem easily.
    • Like Like x 1
    • Agree Agree x 1
  17. Homazur
    Sep 25, 2020
    234
    279
    Woo Hoo!! Bingo! Changed out vacuum pump today and yep it was turning rather not freely and even the round gasket showed some crushing (see photo) and corrosion so I think it was definitely giving false vanos timing faults and engine lights! Once replaced checked and cleared all and ran vanos adaptation and she screams for driving now and no idle issues hopefully (knock on wood) I can relax for awhile now! But hey you know it’s a mini!
    • Like Like x 2
    • Winner Winner x 2
  18. cristo
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    :Thumbsup:Glad to hear you got to the bottom of this.
  19. Homazur
    Sep 25, 2020
    234
    279
    Me 2 and she’s happy!
  20. 00Mini
    Success is a beautiful thing.
