McFly's MINI Adventure
Discussion in 'Car Builds, Projects, Idea's Experiments' started by McFly, Jul 23, 2013.
  1. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    So the time lapse video for the clutch job, both of them, the guy popped the outer ball joint off the knuckle. Suppose I shall do the same. Dave, feel like coming over? Ha!
    Girlfriends and cars do not mix well, wives are not much better but jewelry helps.
  3. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    noted for future reference.
    Tomorrow after church I will take my 20% coupon to harbor freight for a ball joint separator and go to town on the subframe and hopefully get the clutch out.
    I still need to figure out if the valeo clutch kit is neutrally balanced.
  4. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    and it begins... take 2!
  5. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    Got the ball joints off the Control arm by using a floor jack and some well positioned whacks.
    Transmission bolts are all free, all brackets and etc clear. Time to divorce the two.
  6. Minidave
    Support the engine, then put a floor jack under the tranny and away she goes...
  7. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    Engine has a brace up above and the transmission jack under it at the moment
    The Valeo kit has a smaller clutch surface area than the oem clutch. The flywheel came out easily with my craftsman impact gun.
    Also I think I found a witness mark on the Valeo flywheel to match up to the flywheel.
  8. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    Not sure if the Valeo flywheel is neutrally balanced or not. Anyone here know?
  9. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    So the flywheel only bolts on one way
  10. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    #30 McFly, Jul 30, 2013
    Back in!
    I used my cherry picker to lift the transmission up and we slid it home after removing the passenger side half shaft.
    Lunch time now and then reassembly. Replaced the crank sensor seal. It was totally shrunk
  11. Cone Assassin
    Cone Assassin Local Shop Owner
    Jan 7, 2012
    65
    17
    Looking good. Where in central FL are you located?
  12. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    .5 miles behind Magic Kingdom
    so got it all together, took it for a spin. Man is the clutch different now.
    Get home, go to move it again and it does not start! I got lights on the dash and then "click" and nothing at all.
    Currently trying to figure it out. We have narrowed it down to one of the red cables coming off of the battery. But I do not recall messing with those at all
  13. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    Car will not start now. We are getting a short somewhere on the thin red cable from the trunk.
  14. Minidave
    Did you hook the ground cable up near the passenger side motor mount?
    Look for a ground cable loose somewhere....double check the battery cables are tight.
  15. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    uhhhh what? I do not recall any sort of ground cable when removing the subframe.
    I was able to start the car multiple times and drive it around and then I went to start it and nothing. No electrical power anywhere.
    Is there a Body Control Module on this car?
    We have narrowed the short down to somewhere forward engine fuse box(fuse block next to the air filter). Yet when pulling fuses and watching the resistance nothing changed.
  16. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    For some odd reason it is fine now. M
  17. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    Hurray, belt tensioner failure!
  18. Nathan
    Now get a dampened crank pulley such as the ATI.
    Replace that seal too.
  19. ScottinBend
    Yep....get rid of that POS pulley.
  20. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    I was dumb and ordered the PRW from Way... But the box was already on the truck and I couldn't swap it out. and I didn't think of doing the front main. I already did the rear... oh well.
    The pulley is almost off, I just need a longer bolt for the crank snout since I do not want to risk damaging the threads by backing out the oem crank bolt.
    But its coming out nicely. I need to rotate the crank a little bit so the puller clears the body.
    The serpentine belt tool is perfect to wedge against the seat and brake pedal by the way.
