2nd Gen R56 Cooper S Metalman & Crashton/Help On Throttle Body
Discussion in '2nd Generation: 2007+ R55 through R61' started by Jason Montague, Feb 10, 2012.
  1. Jason Montague
    :cornut: Sirs, I need help concerning the precise location of the 'throttle body' on my 08 R56 MCS/JCWm OR does it not have one? I went to REALOEM but one can't plug in a word, one needs a part #. So then I brought up the schematics for my engine and could not find 'throttle body' listed on any of the schematics of: Engine, Intake System, Turbo System, PCV system.................. All that I need is a picture(if possible), location, and what's located upstream and down stream of it.PRETTY PLEASE WITH SUGAR ON TOP.:biggrin5::Thumbsup:
  2. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    I pulled these numbers from penskeparts.com.
    Does this help?
    01 13547576698 THROTTLE 1.71 1 $297.57
    02 13547556492 SCREW SELF-TAPPING 0.02 3 $2.20
    03 61133333333 PLUG HOUSING ON REQUEST 1 $12.92
  3. Jason Montague
    :cornut: Yes and No. At REALOEM these numbers do pull up pictures of a throttle but goes on to say that they are not on my car. So I'll keep trying. Thank you for the help.:Thumbsup:
    I'm thinking your MINI has some double vanos voodoo stuff & does not have a throttle body. I seem to remember reading that somewhere or maybe it was when I was in a donut induced coma. :donut1:
    One might ask why you want to find a throttle body? There are many better places to put your duct tape. :wink:
  5. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
  6. Jason Montague
    :lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol::lol:You're killing me.
    :cornut:I'm now sure that you are correct on my car(08 R56 MCS/JCWm) not having a 'throttle body' as over at REALOEM; I can pull up throttles by part # but it then states that they are not on my car. I must fess up as to purpose of research on throttle bodies and my car. My SEAFOAM posts( and putting it directly into the vacuum intake of the turbo intake pipe ) caused great concerns about my doing this as to possibly damaging my turbo. Sooooooooo I emailed SEAFOAM and they told me that I should get their new Spray Seafoam and spray it in through the (you got it) throttle body. So I guess that I'll get the Seafoam Spray and put it through the vacuum intake of the turbo intake. THOUGHTS?:Thumbsup:
    I just knew someone would have the answer. :Thumbsup:
    You get the best seafoam at high tide on the beach. Wear a personal flotation device. :D
  9. Jason Montague
    :cornut:Thanks Keith.(I did go look at this) Please read my above post and give me your thoughts on what SEAFOAM said about their new Spray Seafoam.:Thumbsup:
  10. Metalman
    Dude....
    Ur makin life way too difficult. What are you going to do.... Try and spray Seafoam into the intake manifold laying on your back under a running MINI on jack stands????
    I seem to recall you installed a BSH connector to the PCV line. I'm guessing there is at least one blocking plug tapped hole not being used??? Replace the cap (temporarily) with one of the extra fittings with a short length of vacuum line. Now with a small container of Seafoam you can inject the liquid right into the PCV line going directly to the intake manifold. Replace with the plug when ur done. Easy Squeezy.....
    Leave that Seafoam guy alone, he needs to find someone with a throttle body he can throttle....:D
    Jason don't forget the duct tape!!!
  12. Jason Montague
    :cornut: Funny but, I didn't call it Duct Tape until after I got out of the Army the first time. In SF we always called it 100mph tape as supposedly the aviation guys used it for minor skin repairs on choppers and it would hold up through 100mph. We used it on parachute drops to secure loose straps,ruck sacks,etc.:Thumbsup:
  13. mbs627
    mbs627 New Member
    Feb 2, 2012
    So many threads are started with "I was doing seafoam treatment to my car and..."
