Mini News MINI Extends Power Steering Pump Warranty on 1st Gen Models
Discussion in 'MINI News and Articles' started by Nathan, May 23, 2013.
  1. philly_stan
    philly_stan Member
    Aug 19, 2012
    42
    Been there, done that... But a MINI is drivable with NO Power Steering as I proved by driving the dragon and hell bender on the way to Fontana in 2012.
    But they have only extended the warranty of the production range listed above up to 02/05 production. Feb 05
    My 2005 prod 05/05 is not covered by the warranty extension.
    3 months after the production range so maybe I have the improved pump.
  3. philly_stan
    philly_stan Member
    Aug 19, 2012
    42
    That stinks, but power steering is over rated... You'll get use to the racks feedback after a while!
    Have you fixed your power steering stan?
  5. ChItalian1027
    ChItalian1027 Member
    Sep 17, 2012
    108
    24
    IT
    Westfield, IN
    Ok, so its based on the service date. Does, that mean when you first bring the car in for service at a Mini dealer? Or when you purchase the car?
  6. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    Got my letter from MINI yesterday - sending off the repair claim on Monday!
    The term is "In Service Date" and it is defined as:
    The date the Vehicle was purchased by the original owner and driven or the date the Vehicle was placed in use for rental, demonstration or other purposes.
    For the vast majority of us that would be the date you signed the papers and drove it off the lot. (assuming new purchase)
    If purchased as a pre-owned you can always call MINI, 866-ASK-MINI, to obtain the In Service Date.
    For Example, my 2006 has a build date of 10/06, yet I did not purchase until 1/8/07. My in service date would be 1/8/07 then.
  8. philly_stan
    philly_stan Member
    Aug 19, 2012
    42
    Yeah, it actually went out on the Foothills Parkway last year on the way to Fontana and I actually had to drive the dragon as hell bender with no power steering... I also had to stop at the TOD because if muscle spasms in forearms and biceps... Luckily Eric from Helix was able to hand deliver one to me and Marzo installed it one morning.
    I'm still pulling together all the paperwork and will likely get the reimbursement... If so, it's an unexpected windfall that will go right into Mods on my other cars.
    Hope your reimbursement comes though smoothly. I sure wouldn't have wanted to drive across the dragon with non operational power steering. You did well to make it to Fontana. :Thumbsup:
  10. philly_stan
    philly_stan Member
    Aug 19, 2012
    42
    Thanks!
    It was an interesting indoctrination, that's for sure ;-)
  11. ChItalian1027
    Sep 17, 2012
    108
    24
    IT
    Westfield, IN
    Thanks for the help Nate.
  12. Dave.0
    #52 Dave.0, May 31, 2013
    If your car was built after Feb 05 I don't care when you took delivery or the "in service" date your warranty started your PS pump is not covered if it was produced after 05 / 05.
    Look in your drives door jam for your production date.
    They switched the pump for cars produced from March 05 on so they are not extending the warranty on those cars.
    Meaning not all 2005 2006 cars are covered only one built up to Feb 05. (Including Feb)
  13. Jason Montague
    :cornut: Aw DaveO. you don't need this warranty anyway. Spies at the Dragon reported that you don't use the steering wheel but ride your 'flaming brakes' instead.:lol::lol::lol::lol:
  14. Dave.0
    For the record I have never set any brakes of fire. I know how to drive and stop.
  15. slumpp
    slumpp New Member
    May 23, 2011
    My letter came as my pump was on it's way to Module Master in Moscow, Idaho
    Yesterday I send Mini a letter asking for reimbursement for my expenses.
    I include the cost of my eBay cooling fan and PS fluid ( no labor charge).
  16. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    I just got home (2:15 AM), turned the MINI off and the pump was still running, had to disconnect the battery to shut it down. I did the low speed fan fix with a resistor a while ago. Just before that, when I was in town the steering went stiff for a moment then returned to normal. From your experience, is my pump dieing? Is this a symptom of the pump about to fail completely?
  17. Mr. Jim
    It has already failed if it will not turn off :(
  18. Norm03s
    Norm03s New Member
    534
    Thanks Mr. Jim, two thoughts come to mind. What I was thinking last night as I was panicky about getting all my junk out of the boot to disconnect the battery then finding the right socket to disconnect the ground wire. Thoughts of that burned up justa I saw in salvage yard last week, not pretty.
    Since this is a warranty issue, I hoping for flat bed service to the dealership, what do ya think?
  19. rkw
    rkw Well-Known Member
    443
    That just happened to me yesterday (steering went stiff, then came back), and now I'm worried about a ticking time bomb. I have a 2006 R52 that won't be covered under the warranty extension.
    For the past couple of weeks, after extended city driving, the fan might turn on for a couple of minutes after parking. This never happened in the past. The car was in the shop yesterday for brake work and I asked about it. They said the steering pump may be starting to fail, and overheating and kicking the fan on. Well it just happened that after I picked up the car and drove to my destination, the power steering died while I was parallel parking into a tight space. Not a good feeling. It was back to normal an hour later when I left.
    Should I try to get it replaced right away? We drive mostly in the city and it would be bad if it went out, especially for my wife.
  20. Norm03s
    Norm03s New Member
    534
    "Should I try to get it replaced right away? We drive mostly in the city and it would be bad if it went out, especially for my wife."
    If you have the use of one car and the wife shares it, absolutely.
    I called my dealer this morning, he told me they are waiting on pumps from Germany and they would have some in two weeks.
